Question about Video Cameras
Recording is to fast .
I have recorded a on cassette tape but has recorded at fast pace and sound is inaudable due to speed of tape. Can thsi be slowed down?
  • 47 Answers
If it is a re recordable cassette, you can record again. But if not you cannot actualyy do anything about it.
Regards
Kanu....
Posted on Sep 09, 2009
  • kanu_guru Sep 09, 2009
    Regards
    Kanu....
Ho do i use the high speed dubbing feature to quickly transfer tapes to my pc using the alesis Dual-Cassette Tape Digital Archiver?
What's your hurry? You copy a tape once but listen to it forever in real-time without fear of it wearing out or degrading. Shouldn't it be as faithful a copy as you can get?
Downloads here:
http://www.alesis.com/tapelinkusb#
A little advice.... if you have any desire to transfer the higher frequencies from your cassettes to your digitized copies, do it at normal speed. The hi-end response of the deck is ok at normal speed but doubling it will double the playback frequencies, making incapable of reproduction with any fidelity.
Frequency Response
(-20dB recording)
Chrome tape 40-15000Hz (±3dB)
Normal tape 40-14000Hz (±3dB)
(0dB recording)
Chrome tape 40-8000Hz (±3dB)
Normal tape 40-8000Hz (±3dB)
Imagine what its response at, say, 30000Hz might be. That's what doubling the playback speed would demand from the head and electronics. It ain't hi-fi anymore.
Feb 13, 2011 | Alesis TapeLink USB Single Cassette Deck
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
You can press play and pause, but then you can't press down rec. help.
Is the erasure prevention tab missing from a commercial or previously recorded cassette? It would leave a little (about 1/8" square) hole in the spine edge of the cassette shell. That tab is there to prevent accidental erasure by allowing a small sensor lever to drop in and mechanically disable the recording mechanism. Compare a commercial cassette with a brand new blank one. You can place a piece of adhesive tape on the casette to allow recording, but take care to NOT cover more than the first 1/8" of the opening if it is larger as the recorder also senses tape type by the length of the hole molded into the cassette.
Word to the wise - don't scrimp on the tape if the recording matters to you. Spend a bit extra for better tapes. Store the tapes 'played', avoid fast forwarding and rewinding unless you'll be playing them through to wrap the tape uniformly before storing it INSIDE its tape box. Read the other warnings that come with the media. No heat, moisture, dust, blah-blah.
Jul 08, 2009 | ION Audio TAPE2PC Single Cassette Deck
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | JVC HR-J461MS VHS VCR
The speed of the recorder
Difference between 4cm and 1.2 cm speed is just like SP and LP speed in VCR etc. 1.2 cm speed selection will give you more recording time on same cassette.
VOR stand for Voice Operated Recording, if you enable this vor option, tape starts recording only at that time when sense any voice and will remain Pause if there is silence.
This option will also give you more recording time at same cassette by skipping empty space.
Sep 17, 2008 | Sony M-675V Handheld Cassette Voice...
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
Tape cassette deck - tape speed too fast in reverse mode only
Be sure the pinch roller behind the capstan is moving into place like it should. Otherwise, the take-up drive will pull the tape through faster than it should.
Dec 18, 2007 | Audio Players & Recorders
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Video Cameras Logo
32 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
