Question about Sharp Office Equipment & Supplies
I have a sharp copier, model AR-5125. I just replaced the toner. I am getting a message F2. Is this something i can fix myself? I live in a rural area and the nearest repairman is 45 minutes away.
  • land4u Sep 09, 2009
    Actually, I fixed the problem myself before I got an email from anybody.
    My copier has a refillable toner cache and I had refilled it already so there was no toner cartridge to check. I do not feel i should have to pay for advice since not only did I fix it myself, his solution did not apply.
    Joyce Elaine Sones
  • 1,869 Answers
Remove and, reseat the toner cartridge then restart
Posted on Sep 10, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F2 is toner error. Make sure all the packing tape was removed from the toner. Try to reseat the toner & check. Also check for difference between versions of cartridges. On the rear side of the toner cartridge there is a plug-in sensor fixed with 2 screws. Try to replace it with the one on the previous cartridge. It can also be due to a faulty toner motor.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 09, 2009
How to fix over heat error message?
www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Jun 11, 2015 | Sharp Copier Toner AR-5132 5125 AR-532NT1
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Olivety
F2 means that an improper cartridge has been installed. Look for the exact type that you used before and it will work.
Mar 26, 2010 | Sharp AR-5320 Black and White Copier
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
