Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Wd portable hd - device attached to this system is malfunctioned
Usb device attached to this system is malfunctioned, windows could not recognize this, other usb disks except this wre detected. I have tried disconnecting and reconnecting on 3 computers with 3 different usb cords - same error.
can data be removed from this portable hard and transfered? or have I lost all the data?
Please advise.
  • 76 Answers
It could be that the Hard Drive inside the enclosure still works, not sure if you care about voiding any warranty as opening it up will likely do, but there is a very slight chance that the Hard Drive itself will let you get the data off it. I am not sure what the connector to the drive is on the inside though as I have not taken one apart myself, :).
Posted on Sep 09, 2009
Testimonial: "Thanks a million. I think I will take it to a data restore specialist to see if it can be recovered. Thanks again!!"
USB device not recogniszed. The device has malfunctioned and windows does not recognize it
You may need USB drivers to recognize the USB drive, especially if it's an older copy of Windows. I would check with the manufacturer for drivers if that's the case. Maybe try it in another machine to make sure it's not defective too.
Mar 27, 2014 | Electronics - Others
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
USB device not recognized. Descriptions: one of the usb device attached to this computer has malfunctioned, and windows does not recognize it. who can help?
I THINK YOUR DEVICE MIGHT BE COMPLAINT THATS WHY THIS MESSAGE IS SHOWN TRY WITH OTHER OTHER PORTS IN THE SAME COMPUTER OR TRY YOUR DEVICE WITH OTHER SYSTEM ALSO IF THE PROBLEM IS STILL THERE YOUR DEVICE MIGHT HAVE GOT SOME INTERNAL BREAKAGE INSIDE I THINK THE USB CABLE MIGHT HAVE DAMAGED OR JUST THINK BACK HAVE YOU EVER REMOVED THE DEVICE FROM THE SYSTEM WITH OUT USING THE SAFE REMOVAL APPLICATION IN WINDOWS OR ANY OTHER OPERATING SYSTEM IF SO THAT NAY THE PROBLEM WHICH LEAD TO MALFUCTIONING REMBER WHEN A DEVICE IS BEING ATTACHED ALWAYS USE SAFE REMOVAL TO REMOVE ND ALSO THINK BACK WETHER IT MIGHT HAVE FALLEN FROM YOUR HAND
Oct 18, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
One of the USB devices attach to this computer
One of the USB devices attach to this computer has malfunction, and windows does not recognize it
May 12, 2009 | Samsung YP-U2 MP3 Player
Aloha, I have a WD (Western Digital) external hard drive with information from my old computer (which just crashed). However when I plug in the usb device not recognized - one of the usb devices attached...
you just have to get someone that know more about window operating system setup, nearby to help to scan the Hard drive, by using window setup repairs gooluck
Jan 24, 2009 | Computers & Internet
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
453 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
