Question about Radio Communications
Kenwood ts-820 my kenwood ts-820 keeps blowing its main fuse ,where do i look for the problem,I am just trying to learn how to trouble shhoot thank you
If your fuse is blowing as soon as power is supplied, then the problem is on your " rectifier unit " board. This is a voltage doubler circuit, and either one of the four diodes (D1-D2-D3-D4) is shorted. One of their filters (C21 or C22) could also be shorted, and may have lead to the destruction of one of the above mentioned diodes. After finding and making repairs, I would suggest bringing the unit up with a variac, while monitoring the AC amperage that will be drawn. Hope this helps. Jim
Posted on Oct 01, 2008
There are so many possibilities as to the cause of your fuse blowing that I feel compelled to refer you to other owners of TS 820 transceivers. You will be best advised through them. These radios are thirty five years old and have their power supply capacitors dry out, for instance. Many have had modifications and some have had abusive treatment ruin them. There is HT doubling circuitry which could leave you open to about a kilovolt in and around the capacitors and this can easily kill you. There is a group which exists on the internet which can help you further. I suggest you search it out. Make a search under your transceiver's name. 73 de Bob VK4GCA
Posted on May 02, 2008
Look in the rectifire section of the power supply (the bridge rectifire).
Posted on Feb 05, 2008
How to install a voice synthesizer into a Kenwood ts 570
This should be of some help to you...
Mar 02, 2015 | Kenwood Radio Communications
Tablet wont turn off
check your tab connector it may be damaged or out of place or loose, if loose it make contact with casing ,thinking is being used by an otg...hope this helps...then just follow trouble shhooting guides, holding down vol then power hold for at least 30 to 45 seconds then release power and then vol, wait about 2 mins before tab completly shuts down ...youll no longer hear the sound of a tab trying to keep running....times are approximate..if it doest help keep on reading ..eventually you'll find a few suggestions that may work together....
Dec 09, 2013 | Tablets & eReaders
Kenwood TS-820 Receive Help
One of the RF gains stages is not working, or there's a self-oscillation in the receiver. I'm afraid it needs to go to a Kenwood shop or their service center.
Jun 29, 2013 | Radio Communications
Main fuse keeps blowing
You stated your loadtested battery? Try another known good battery as I have seen very odd things happen with these maintainence free batterys sometimes such as polarity swapping. This would cause the same main fuse blowing as if you were hooking the battery up backwards.Then begin by un plugging the ignition switch. If fuse blowing stops the problem is in the harness somewhere between the fuse and ign. switch. Possible wire pinched or rubbed through and grounding. From the ignition switch the main fuse voltage goes to the distribution(common) side of the fuse box. Inspect the wiring from the switch to the fuse box. This problem has to be pre fuse box in location otherwise the lower amperage circuit fuse in the box would be blowing. Good luck!
Dec 30, 2012 | 2007 Suzuki GSX-R 600
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
How hard is it to replace the finals in a kenwood ts-2000
Hi Damon,
It's Bloomin' hard, and it's tricky if you have little technical knowledge.
Yes Kenwood is a darn good brand, so to keep your Kenwood darn good, pay for the repairs, it's darn worth it.
Jul 02, 2012 | Kenwood TS-2000
My 1800w kenwood amp keeps blowing the fuses
there are 3 reasons your amp is blowing fuses. The first is that it is no good. If amp plays at all then that is not the case.
Then it is more likely 1 of or both of these 2 reasons.
  1. The fuse is too small for the load you are putting on it and needs a bigger one.
  2. You have the amp wired to an ohm load that is too low.
Try upping the fuse to the next size up.
If the amp just blows the fuse and will not work at all. It may be shot.
Dec 02, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Kenwood TS-820s almost dead
Dear Stigw1:
I have your answer for you. I have the same unit which had a few problems. Sent it to this fellow I'm about to tell you about who works on NOTHING but the Kenwood hybrids such as the ones we have. He is amazing. He'll take your TS-820S and literally bring it back to BRAND NEW condition for you, just like it left the factory. His general repair price is $229.00 (US dollars) plus parts. If he doesn't have the part(s), he'll actually make them!! My radio was shipped to him in Sept. of '08 and it's now in the mail back to me (Jan '09). You pay shipping both ways. Go to this website and check it out... . His name is: Ken Kemski, 3745 Allenwood St., Sarasota, Florida 34232 (USA). His work is worth the money all day long. If this helps you, PLEASE let me know. -- 73's -- Johnny Downing - Jan 2, 2009
Dec 17, 2008 | Radio Communications
Remote control cable
Within the same manual, you'll find a section that may say: Additional Accessories.
The cable should be listed as an accessory item to order.
Contact Kenwood and ask them how to order the cable.
Oct 22, 2008 | Radio Communications
Radio Communications Logo
397 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
