Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Gas smell I have an electric whirlpool stackable washer dryer and lately there has been a smell of gas or propane coming from the dryer which gets on the clothes as well. Is this because of overheating? Is there a fire hazard?
    Scholar:
  • 196 Answers
Fire Hazzard ? YES !! Sounds like the ignitor is taking too long to lite the gas. This lets the gas trickle into the machine. It is very important to the operation that the ignitor lite within 30 seconds on the first try and within 20 seconds thereafter.
Posted on Dec 30, 2007
Whirlpool wgd9400swo. Gas clothes dryer The burner only stays lit for 1 minute the new goes out, tries to re-light but can't seem to
The limit switch is bad. most likely or the igniter. Does it give off a gas smell? If it is propane you can really smell it. But Natural Gas You may not.
Nov 08, 2016 | Whirlpool Dryers
Can a stackable washer and dryer be both gas and electric?
yes, the washer is electric, and the dryer could be gas, all though i have only seen in a stackable modles that i use to eliver for sears, that it was also electric, thats not to say thatthe anufacure does not make it
Mar 29, 2011 | Washing Machines
I just installed this stackable whirlpool washer and dryer everything works good except the heating element will not come on what to do
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 18, 2010 | Dryers
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Feb 22, 2008 | Whirlpool LER5636P Electric Dryer
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Whrilpool gas dryer
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Jan 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
123 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
