Question about Akai CTD-1390 TV
Akai TV/DVD player
I have an AKAI 13" CTD-1390 TV (with a DVD player inside of it). When I put in a DVD, even one that used to work on it, it says "unknown disc." I can hear the DVD spinning but it "clicks" more than "whirls" like a normal DVD player.
4 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: akai pt5299hd
I just repaired a Hitchi with the same problem ( I had to do a full adjust on the convergence board via a remote control) I finally came up with a set of instructions to do the full converg. I don't know if these instructions would be helpful for you or somewhat match your set, but send me your fax number and I'll fax the instruction sheet to you ( as I received them). Wyoed1@aol.com, NC Electronic, PO Box 1696, Mills, Wyoming 82644 307-266-4675
Posted on Jan 05, 2008
SOURCE: Akai CTD-1390 TV it doesn't turn on
al tv esta bloquea y no recuerdo la clave como hago
Posted on Mar 03, 2008
gopakumarg43
  • 75591 Answers
SOURCE: There are blurry lines, distorted images, with no color on the screen of the AKAI CTD 1390, 13 inch TV/DVD combo. How do I fix this?
Video output section circuit [CRT base card]; fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 15, 2014
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Televison & Video
I have the color back on the AKAI/CTD 1390, but the wavy lines and distorted images return after watching the t.v. for several hours. This is a T.V./DVD combination. Thank you for your help.
Fault with the main power supply regulator section circuit.. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 17, 2014 | Akai CTD-1390 TV
Nov 14, 2014 | Akai CTD-1390 TV
When I switch to DVD mode the screen stays blank. DVD which is in it does not play nor will it eject.
a loose interfaced connection could caused this problem try to clean the connector and make another test attemp
Jul 14, 2011 | Akai CTD-1390 TV
Remote not working, new battery. Need replacement. Why would it not work and is there something I can do to fix it?
Try fixing your remote control
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 24, 2010 | Akai CTD-1390 TV
My tv is on child lock mode and i do not know how to change it the model is akai ctd1390
my tv akai ctd1390 is lock i dont have the remote now
what can i do ? to unlock it
Sep 16, 2009 | Akai CTD-1390 TV
Feb 02, 2008 | Akai CTD-1390 TV
Piece of s@#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
Oct 20, 2007 | Akai CTD-1390 TV
Akai CTD-1390 TV Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
