Question about Olympus SP-350 Digital Camera
I am not getting the suff.no of snaps as batt is getting down for olympus( sp-350) . i have tried several type of AA 2500 mAh Ni-MH battery and purchased new LCD (simpex) charger.then also same.also when ever i am replacing the battery it is asking to set the time. probably another battery is there which i coul'd able to locate. with regards amitava
    President:
  • 2,761 Answers
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Posted on Sep 10, 2009
Olympus solution is Firmware update 1.4
Go to http://www.olympus.co.jp/en/support/imsg/digicamera/download/software/#sp
* Upgrade history *
SP-350 / SP-310 Firmware Ver1.3 has incorporated the following upgrade.
Low battery indicator has been adjusted for rechargeable batteries.
Posted on Oct 12, 2009
I put a new set of Ni-Mh AA battery with 2100 mAh, still after just 30 odd snaps with flash its started to show the batteries' down.. please help! the camera is just 2 days old.. its finepix s1800...!
try with other type of rechargeable batteries.Duracell or Energizer will do the best. Read carefully on the package the year when battery was made. Over 2-3 years,the electrolite from the batteries may became dry, reducing the power capacity. You must buy fresh battery. But you must know that many digital cameras drain more than 2 Ampere from the batteries even without flash on. That means you need minimum 2700 mA/h cells to last longer. I hope this will help you.
Sep 30, 2010 | Cameras
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Batteries type
Four AA-size alkaline batteries, lithium batteries, and Nickel-Metal Hydride (Ni-MH) batteries can be used. The D-460/490 Zoom can also use two Olympus CR-V3 (LB-01) long-life lithium batteries. Olympus recommends the use of Ni-MH batteries or CR-V3 long-life lithium batteries (where applicable).
Sep 04, 2005 | Olympus Camedia C-960 Zoom Digital Camera
Batteries type
Aug 31, 2005 | Olympus D-490 Zoom Digital Camera
Batteries type
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Batteries type
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Batteries
You can use alkaline batteries, lithium batteries, and nickel metal hydride (Ni-MH) AA batteries. Olympus recommends using Ni-MH batteries for longer life.
Aug 31, 2005 | Olympus Camedia D-360L Digital Camera
Batteries
Aug 31, 2005 | Olympus D-320L Digital Camera
Olympus SP-350 Digital Camera Logo
143 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
