I have a c3140 and i cant get the ink cartridge
I have a c3140 and i cant get the ink cartridge in
2 Suggested Answers
mrbench87
  • 40 Answers
SOURCE: photo ink cartridge
remove the black ink cartridge and insert the PHOTO cartrdige to the black ink slot and im pretty sure that it will perfectly work...
Posted on Aug 31, 2008
HP PhotoSmart C3140 All-In-One Inkjet Printer will not print in color
ok let's try this
Step One: Remove, inspect, and reseat the problem cartridge
Figura 4: Opening the printer cover (make sure the power is on)
c00308401.gif The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
[img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
NOTA:HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  • Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  • Press down lightly on the end of the problem cartridge to release it. Figura 5: Removing the tri-color cartridge
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c00484998.gif" alt="" border="0">
  • Slide the cartridge out and inspect it: [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/caution.png" alt="">
    ATTENZIONEDo not touch the copper electrical contacts or the ink nozzles.
    Figura 6: Electrical contacts and nozzles
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/640/c00211537.gif" alt="" border="0">1 - Copper electrical contacts
    2 - Nozzles
    Check the electrical contacts for debris.
    Make sure all the clear nozzle protective tape has been removed.
    ATTENZIONEDo not attempt to remove the copper electrical strip!
    Figura 7: Removing the clear nozzle protective tape
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/767/c00211538.gif" alt="" border="0">Printer Reference Guide supplied with your printer.
  • If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figura 8: Sliding the cartridge into the carriage
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/222/c00484999.gif" alt="" border="0"> Figura 9: Pushing the cartridge into place
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/408/c00485000.gif" alt="" border="0">
  • Step Two: Clean the problem cartridge contacts
    1. Gather the following items to clean the cartridge and carriage:
      • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
      • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
      • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
    2. Open the cartridge access door and wait until the carriage is idle and silent.
    3. Disconnect the power cord from the back of the printer.
    4. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
      NOTA:Do not leave the cartridges outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles.
    5. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
    6. Clean only the copper-colored contacts
      Figura 10: Clean the contacts
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/172/c01954145.gif" alt="" border="0">1 - Copper-colored contacts
      2 - Ink nozzles (do not clean)
    7. Repeat these steps for the other cartridge.
    8. Lightly moisten another cotton swab with distilled water, and then squeeze any excess water from the swab.
    9. Use the swab to clean the electrical contacts in the carriage, located inside the printer on the carriage slots.
      Figura 11: The electrical contacts in the cartridge slots
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/869/c03743456.gif" alt="Image: The electrical contacts in the cartridge slots" title="Image: The electrical contacts in the cartridge slots" border="0">
    10. Wait 10 minutes to allow the cartridge and carriage electrical contacts to dry.
    11. Reinstall the cartridges.
    12. Close the cartridge access door.
    13. Reconnect the power cord to the back of the printer.
    14. Press the Power button to turn on the printer.
    15. Try to print a page.
    16. If you are still unable to print, repeat these steps to clean and reseat the cartridges. Multiple cleanings might be necessary to restore printing.
    Figura 12: Print carriage contacts
    c00906469.gif Step Three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above
    Apr 04, 2014 | HP PhotoSmart C3140 All-In-One InkJet...
    Says in quire bur won"t print
    HP typical junk and user error problem . check all connections align paper check ink cartridges. check if hp will assist from they're technical support page.
    Aug 21, 2013 | HP PhotoSmart C3140 All-In-One InkJet...
    Where is the ink cartridge located on the HP c3140 and how to I get to it?
    From the manual:
    Make sure the HP All-in-One is on.
    Caution If the HP All-in-One is off when you open the print cartridge door
    to access the print cartridges, the HP All-in-One will not release the
    cartridges for changing. You might damage the HP All-in-One if the print
    cartridges are not docked safely when you try to remove them.
    2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
    3. Open the print cartridge door.
    The print carriage moves to the far right side of the HP All-in-One.
    4. Wait until the print carriage is idle and silent, and then lightly press down on a
    print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the
    slot on the left.
    If you are replacing the black or photo print cartridge, remove the print cartridge
    from the slot on the right.
    Chapter 1
    14 HP Photosmart C3100 All-in-One series
    HP All-in-One overview
    1 Print cartridge slot for the tri-color print cartridge
    2 Print cartridge slot for the black and photo print cartridge
    Jul 24, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
    My printer HP Photosmart C3140 prints but nothing prints. What seems to be the problem?
    Check the ink cartridge levels to make sure you can print, the manual will guide you through the procedure if you are not sure.
    Jan 01, 2011 | Office Equipment & Supplies
    CANNOT INSERT A NEW INK CARTRIDGE- HOW DO I INSERT A NEW CARTRIDGE
    Hi
    I have put a PDF files on my website for you to download.
    Hp C3180 Manual-C3100-C3110-C3125-C3135-C3140-C3150 -C3180.pdf
    Just click on the links it will download for you.
    It got all you need to know in this file,
    Click LINK= http://www.4all2sell.com/pdf/Manual-C3100-C3110-C3125-C3135-C3140-C3150 -C3180.pdf
    You will need adobe reader to see this file If you not got a Pdf reader you can download it off this link free.
    http://www.adobe.com/products/reader/
    Fills on my website are only there for a limited time and will be deleted Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 11, 2010 | HP Photosmart C3180 All-In-One InkJet...
    Installed updates now HP printer won't accept refilled ink
    HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
    Mar 11, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
    I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
    I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
    You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
    http://welcome.hp.com/country/au/en/support.html
    NOTEs:
    1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
    2. When you are printing a final copy then switch from DRAFT to BEST quality.
    Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
    Printer has power, but nothing works!
    http://www.hp.com/#Support
    Follow the link and get the correct driver and get installed
    Oct 21, 2009 | HP PhotoSmart C3140 All-In-One InkJet...
    Photo ink cartridge
    Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
    27 people viewed this question
    jasbo
    jasbo
