Question about Brother Sewing Machines
There is an error on the screen saying N_Case POS. Error for the BES-1210ac
HOW TO STOP EXCESSIVE SHREDDING AND BREAKING OF THREAD ON A BES-1210AC
Sorry, do not recognize the make model machine.
Be sure to use good quality thread--NO old or bargain bin threads or thread that shows "fuzzies" projecting from the thread!
Use needles that are compatible with the thread and fabric being stitched.
Check that there are no burrs or rough spots in the thread path--also check the needle plate and bobbin/hook area for rough spots that could snag the thread.
Dec 23, 2017 | Sewing Machines
The display says Error # 1
Unable to help without knowing the make/model of the machine. Sometimes the error codes are listed in the troubleshooting section of the user's manual.
Apr 09, 2016 | Sewing Machines
What is e4 error code on janome 7700qcp sewing machine
sounds like repair shop time as timing has slipped needle hitting bobbin case possibly
Feb 12, 2015 | Janome Sewing Machines
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
Feb 08, 2015 | Sewing Machines
Recently had D1 color screen. Now I cannot load floppies or disks. I keep getting error messages. I did re calibrate the machine. Any suggestions is appreciated. Thx
Sound like your floppy disk drive has failed. However, if you have a vacum that will blow, try blowing air into the disk drive in case it has some thread or other debris in it. Good Luck!
Jan 05, 2015 | Sewing Machines
What is problem with PC-Designer. I am trying to send from computer to 7570 Pfaff and it gives an error of "Floating-Point error: Stack Under" I don't know what that means nor do I know what to do.
When it comes to machine errors the mfg is the best to talk to. Call thier customer service if there's a phone number. If not, do a search on the internet for the name of the mfg (manufacture). Email customer service. Have the model and year of when the sewing machine Was made.
Sep 12, 2014 | Sewing Machines
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
My babylock says THE SAFETY DEVICE HAS BEEN ACTIVATED. The belt is not broke. I have changed the needle and pressure foot and still when you start to sew it does nothing and the above wording comes...
When you get that error message it usally means there is a jam in the machine that is causing the motor to work to hard so it keeps you from burning up the motor try taking your needle plate off and bobbin case out and then put your needle plate back on and then the bobbin case if that doesnt work try looking at the take-up lever there might be thread wraped around it soaking up the oil and causing a bind
Jul 02, 2009 | Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
