Question about Kitchen Ranges
The Oven Exploded with a Whoosh when I Opened the Door
I've used the oven spaingly over the five years. I hadn't used it all summer. I placed french fries on a cookie sheet, put the cookie sheet in the oven, and set the temperature on the oven to 450 degrees. After 5 minutes, I returned to the kitchen and opened the oven door to check on my french fries. A huge ball of yellow fire ignited and engulfed me. It lasted less than 1 second. My hair was singed on my head and face. The hair on my arm was gone. My beard saved my face, but my nose now has blisters. My cheek is a little pink.
    Sergeant:
  • 222 Answers
Wow !
sounds like a bad initor and or a bad safety valve, i would replace the gas valve at the rear completely and while you have the gass off and disconnected see if your ignitor glows, even if it does glow it could still be bad it neeeds to draw enough amps to open the gas valve, be careful
Posted on Sep 10, 2009
I was using my oven when all of a sudden there was a loud whoosh sound. Since I use propane I immediately turned off the oven.
Hi, it sounds like you may have a gas leak some where else on your oven probably from the supply pipe . It looks like it is building up then its been ignited so you get a whoosh. Best get it checked out.
Jan 30, 2016 | Kitchen Ranges
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
Oven does not turn off when the door is opened.
Check the door latches. If one is broken and stuck in, the microwave will not switch off when being used failing that call a microwave repair service.
Apr 22, 2017 | Whirlpool Microwave Ovens
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
Dec 17, 2017 | Baumatic B180SS And B60SS (Bundle)...
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
Self cleaning oven door lock is stuck and buzzing
you can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
Feb 04, 2009 | Frigidaire GLEF396 Electric Kitchen Range
Micro oven-Not working
Hello Kavithaanto,
If I understand your problem correctly, it sounds as if your microwave was operating and the egg exploded after 5 minutes ( which caused the door to open), after cleaning up the mess, you tried it again and it does not work. If that is true, then there is a high probability that your microwave has a damaged Magnetron Tube, Filament Transformer or High Voltage Capacitor.. none of which are something the untrained person should attempt to repair. Since your microwave is a table top model, I recommend that you consider purchasing a new one. The cost to repair would exceed the cost to replace so it is not worth it. I am sorry that I couldn't provide a more encouraging solution.
Best Regards,
Rick
Nov 26, 2008 | Sharp R-1480 Microwave Oven
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
