Gas furnace for mobile home, Coleman DGAM056BDD, attic fan runs continuously.
  • 92 Answers
Is your thermostat set to on?That would make it run continuously.There is a relay in the Coleman unit that could be stuck. Good luck--
Posted on Sep 10, 2009
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
How do I get the panels back on my Coleman motor home furnace? I changed the filters and now I can't get the panels back on
please one post,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman 7956-336p Mobile Home Furnace Gas...
I have a coleman modulating furnace it is propane The buners seem to be corroding
There are 2 types of burners. Atmospheric (or ribbon) type & inshot. I would imagine yours are Atmospheric...the longer type burners that protrude into the heat exchanger if they are corroding. Which also means you have an older furnace. Condensation can occur if there is not enough removal of flue gas...or... water is getting down into the burner from the flue. Have someone check the draft pressure to see if it has a proper draw when running. Coleman Evcon also made a furnace that is called a blendaire system. This system has a lower control board @ the furnace & and upper control board in a fan on the roof. The purpose of the fan was to blend air into the return from outside via roof fan to introduce fresh air in a tightly enveloped manufactured home, along with pressurizing the attic space to help keep the attic dry. If you have this type of system, your motor may be not working on the roof. Good luck!
Dec 02, 2014 | Heating & Cooling
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Furnace fan will not shut off
if the fan just runs check the limits there is about three of them and a high limit some of them are Manuel rest witch means you have to press the button on them
Dec 25, 2012 | Coleman Mobile Modular Home Gas Furnace...
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
298 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
