Question about Panasonic TH-50PX75U Plasma HDTV
TV Cable Audio Problem
I am having problems with my tv audio...but it only seems to happen with the cable channels, not the dvd player???
    Scholar:
  • 53 Answers
The A/V cable might be bad try a different cable, if the cable is good try change the audio input settings on the TV by going to the menu and on the audio options select the one that works the best for you.
Posted on Dec 14, 2007
Tying to hook-up my 1100 dvd player to tv I have the three cables white yellow and red audio out to audio in on tv. the recoder plays but no picture. is the a certain channel i should be on?
The connection should be the cable box out to the DVD in, the DVD out to the set. The DVD should have a channel select, Either 3 or 4- set it to the channel that is not used by the cable decoder. which should also have a switch for 3 or 4.
Then all you do is switch between channel 3 or channel 4 with the TV remote or by TV channel buttons. One will be cable, the other will be the DVD.
Dec 22, 2011 | Spectroniq PD-1100 DVD Player
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio Players & Recorders
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
When I connect a DVD player, there is no audio or video.
Select "Video 1",or whichever input you have connected the player to. It is not available on "channel...accordianman
Nov 12, 2008 | Toshiba 27A33 27" TV
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
How to use DVD player along with cable box wih this tv
The audio out jacks in the back of the cable box can support up to 5.1 channels of audio to a home theater system. Take the DVD player and plug it into the TV with only the video cable and the audio cables into the theater syste. If you have and questions you can ask and if pictures are needed than I can post them.
Apr 20, 2008 | RCA F25432 25" TV
Proper input for TV audio signal
Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
Feb 16, 2008 | Pioneer VSX-D812 Receiver
Panasonic TH-50PX75U Plasma HDTV Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
