Question about Kenmore 51lb. Clear Ice Maker
I am looking for a schematic for the kenmore 51 lbs ice maker
When turning on the ice maker water continue to flow into the water compartment however it runs out the bottom. I do not remember a cap being underneath to contain the water? No help from Sears. I thought the mere view of the schematic will tell me immediately. Thanks Leo
  • 93 Answers
If you are saying that the icemaker is filling with too much water and spilling water into the freezer then probably yout icemaker module is bad, Also make sure there is no ice inthe fill cup of the icemaker.
Posted on Sep 12, 2009
  • Kenmore Master
  • 1,606 Answers
There is supposed to be a cap or plug , at the bottom of the water bucket , to hold water for the recirculating pump . There is no cap at the bottom of the ice bin .
Posted on Sep 09, 2009
Kenmore ultra fresh side side 59507990
828a4e4f-c0b3-4029-a7f5-35b92db8b7ad.jpgKenmore model numbers look like this example=> 321.1234578 Are you sure that the water in the ice maker is melting and flowing down into the ice bin? What may be happening is the water control valve for the ice maker may be allowing water to continue flowing into the ice maker tray even when off due to the water control valve being defective. If your refrigerator also has a water dispenser and the water is not continuing to leak is because the water control valve has to sides. One side is for the ice maker and the other side is for the water dispenser. I am here if you have questions, Thanks Sea Breeze
May 29, 2013 | GE Refrigerators
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
Ice maker is overflowing
If water continues to flow slowly after filling the water control valve for your model will need to be replaced=> 241734301 Water Inlet Valve
If ice maker simply over fills and then the water turns itself off then this points to a problem with the ice maker=> 5303918344 Ice Maker Assembly
I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 12, 2012 | Kenmore Refrigerators
Icemaker isn't working. Hot water pouring out
Most ice makers do have a defrost element below the ice maker. The problem you described is strange. I would like the model of the refrigerator and brand name. Unplug refrigerator and remove ice maker from freezer compartment now. If water continues to flow you may need the service line that feeds refrigerator turned off until I get your model number. Thanks, Sea Breeze
Feb 15, 2010 | Refrigerators
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker does not work on 1068552780. Does not appear to request the water. regular water dispenser works ok
On a lot of models there is a level instead the maker that turns it of. sometimes this will accidentally hit while inside the ice compartment. The filter seems to be working if you are getting water flow. Is the water flow slow or is it pretty fast.
Apr 27, 2009 | Kenmore Refrigerators
Ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Sep 13, 2008 | Samsung RM255LASH Side by Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Dec 31, 2006 | Amana ARS266ZBS Side by Side Refrigerator
Kenmore 51lb. Clear Ice Maker Logo
268 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Sal DeAngelo
christian nielsen
Shehu Pro
Shehu Pro
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
