Question about DeLonghi D406DZ Dual Zone Deep Fryer
Delonghi D406DZ light will not come on?
If the light does not come on recheck how the base unit is connected to the main fryer, if it is not connected correctly the light will not come on
this is the solution to fix the problem
2 Suggested Answers
SOURCE: delonghi fryer
I broke the plastic mount that holds the controls against the outside of the frame. That plastic mount was depressing a switch that is no longer being depressed. I get an Error message too. I'm going to try to contact the manufacturer to see if I can get a replacement part. (I doubt I can because the model is discontinued).
Posted on Aug 25, 2008
I have a LP gas commercial deep fryer and the pilot will light and the burners will light without the use of a thermostat control(new).when I turn the therm on everything goes out.
It should only work when thermostat is turned on recheck stat and connections it sounds as this is working backwards also check for gas leaks
Nov 03, 2016 | Kitchen Appliances - Others
Delonghi deep fryer D14527DZ
Hi there.
You can download Owner's Manual for your fryer at the Cutomer care tab on http://www.delonghiusa.com
Regards.
Nov 26, 2011 | DeLonghi D14527DZ Dual Zone Deep Fryer
D14527DZ Delonghi deep fryer
Hi there.
You can download Owner's Manual for your fryer on the Customer Care tab of http://www.delonghiusa.com.
Regards.
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
I need a instruction manual for a de longhi roto fryer
Hi there.
You can get Owner's Manual of your Roto Fryer at the Kitchen Appliances page of http://www.delonghi.com
Regards.
Feb 26, 2011 | DeLonghi Roto Fryer F2872 Deep Fryer
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Main burner will not light or goes out before grease reaches temperature.
before replacing any parts,clean out the pilot,burner orfices and burners.if this doesnt solve your problem replace the thermopile.call 18884hobart and get the parts dept.tell them you need a thermopile for the model of your fryer.95% of the time the t-pile goes bad.theres also the hilimit in the unit that kills the gas if the fryer gets too hot but i dont think thats the problem.also check all wiring connections to the gas valve (clean and free of grease).drain the oil in the tank and youll see 2 bulbs ones the thermostat bulb the others the hilimit bulb.make sure their secured to the bracket.
Jan 06, 2008 | Vulcan EF3 Deep Fryer
DeLonghi D406DZ Dual Zone Deep Fryer Logo
52 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Paul Bade
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
