Question about Kenmore Dishwashers
Kenmore portable dishwasher model 66517762K600 won't drain reliably. It sometimes doesn't drain at all and other times only partially regardless of the cycle.
  • 2 more comments
  • bika0401 Oct 03, 2009
    Thanks for the fast reply but I'm afraid there are several areas I don't understand and need to clarify.
    First--the water that is left in the bottom often is very deep and dirty and as such the dishes are not rerally clean (about 1" in depth).
    Second--this is a portable dishwasher and the hoses that come out of the dishwasher back are not kinked. They don't appear blocked but how would I tell? Also--what is a "knockout?" A "disposer or plug???" Where are these things and how do we remove them? How do we get to the inside hoses? Where and what is the air gap?
    Do you have a diagram of a dishwasher and parts?
    If it is the drain pump--how do we access it and replace it?
    See less
  • bika0401 Oct 09, 2009
    We have a kenmore portable dishwasher model 66517762K600 and it won't drain reliably. It sometimes drains fine but other times it doesn't drain at all and leaves a large amount of dirty water in the bottom.
    This is a 4ish year old portable dishwasher and the hoses that come out of the dishwasher back are not kinked. They don't appear blocked but how would I tell? Is there more hose on the inside that we should check?
    Thanks.
  • bika0401 Oct 11, 2009
    okay
    President:
  • 803 Answers
It is probably plugged up with dirt or grime. I had a case where my drain tube/pipe was plugged up. After I disconnected it, it emptied out, and after I reconnected it, it worked fine. I also found stuff inside on the bottom that I cleaned out.
Posted on Oct 10, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 03, 2009
  • 788 Answers
Check your discharge hose for kinks or blockage. Feel the hose, if it is soft in areas where it bends, it may be restricting the water flow.
Also you may have a belt or pulley driven unit and the belt may be slipping or need replacement.
Last off, depending upon the age and amount of usage of the unit, the pump may need replacement. I am sure that you have checked inside at the base of the unit for obstructions.
Posted on Oct 04, 2009
  • John Ray Oct 11, 2009
    Sorry I took so long to reply to your second request for information.
    Ok, if you have water standing in the dishwasher after a normal cycle, you have a problem, eiather in a restriction in the drain line or a blockage in or before the pump.
    The best way
    Ok, sorry I could not get back to you in regards to your dishwasher problems.
    First, if you have standing water in the base of the unit after a normal cycle, you have a problem either at or before the pump.
    You should remove the dishwasher and flush out the entire system with a garden hose.
    Inside the out, at the base, you should see a area where the water drains from. There may be a plastic cover of this area, may be clogged.
    Outside the unit, the drain hose, you can either remove this at the base or leave it on. This can also be flushed out with a garden hose.
    Also, keeping the drain hose low to the ground, with help remove and obstructions while flushing.
    After you have finished, you can move the unit to a dry area, (outside) and test it.
    You can run a short extension cord to power up the unit.
    After the inside is washed out, fill with a hose about 2 inches and try a manual draining.
    If the timer brings the unit in and out of cycles and the unit still does not drain sufficiently, you may need to replace the pump.
    P.S. If you are testing unit as described above, please keep area dry and all electrical wires out of and away from the water.
    Last of all, I do not have a diagram of your unit.
    Thank you.
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
My kenmore ultra dishwasher won't drain. how do i go about checking and repairing it?
Hi
Daniel
Aug 03, 2011 | Dishwashers
Kenmore 15652 model. won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Apr 22, 2011 | Kenmore 24 in. 15652 Built-in Dishwasher
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Dishwashers Logo
98 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
