Question about Sub-Zero 690 Side by Side Refrigerator
Evaperator coil has gone bad. How much should it
Evaperator coil has gone bad. How much should it cost to repair?
  • 10,515 Answers
The cost would be $750 + Labour.
You can get a Maximum of 1 year warranty, if you change the Evaporator coil.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
Bosch frig/freezer fan icing up... How can I stop the problem?
This could be caused by 1 of 2 problems.
1. Your evaperator coils could be clogged with dust. Clean with a vacuum hose.
2. If that is not the problem, the freon pressure is probably low and this is caused by a leak. This would require a professional repair person. How old is the frig? Sometimes they are not worth the repair cost.
Mar 09, 2015 | Bosch Refrigerators
HAVE A GE REFRIGERATOR TYPE TFX25CR THAT LEAKES WATER FROM TIME TO TIME, ABOUT 5 OZ
The evaperator for the drip under the bottom of the unit is probably dirty or has gone bad. Pull the fridge out and look under the bottom and you should see a pan with a coil above it. Clean the coil and the pan. If this does not correct the problem, then a new coil is in order. Also vacuum the back of the fridg if it has exposed coils to increase efficiency.
Dec 15, 2014 | GE Refrigerators
Freezer on and off
Could be a couple problems. The thermostat may not be making the contacts close to tell the compresser to turn on all the time. The compresser could be overloading which would be caused by overheating (clean the condenser). The freezer and frige evaperators may be becoming frozen up due to a bad defrost timer. When the freezer warms up check to see if the compresser is running, if it is not put your hand un it, if it is hot then it's overloading and should be replaced. If it is running and isn't really hot check to make sure all of the fans are running, should be one condenser fan and one on each evaperator. And look for ice build up inside the freezer and fridge. If all the fans are running and coils are clear and compresser is running next st is a plugged cap tube which is the metering device to the evaperators. The mechanic can trim them down six inches and fill the system and they should work great again. Hope this helps
Sep 06, 2012 | Jenn-Air Refrigerators
Whirlpool side by side refrigerator freezer side evaperator coil frozen
HI.FELICIA.i think u need a technician to check and test the components before getting parts.but u can try .1-defrost completely first.then turn on.initially it should work..(clean condensing unit properly front to rear end first).if it freezes up again thennn it could be the heater;t/stat;defrost timer/pcb board.hope this helps.good luck
Jun 27, 2012 | Whirlpool Refrigerators
Need to find the low pressure port on my 06 for tarus
The AC low pressure port is in the line between the evaperator and the compressor. The evaperator is the coil in the dash unit. It should have a screw on cap and is a snap on connector.
Aug 03, 2011 | 2006 Ford Taurus
How to fix ice build up on the evaperator coils of a window a/c unit
Your in the wrong form group!
"Problem with Microsoft Windows XP Home Edition"
Seems you need to in form group "window a./c evaperator coil ice build up" Not windows computer XP issue! Check it out.
Aug 21, 2010 | Microsoft Windows XP Home Edition
Our Amana fridge freezer has stopped chilling and freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Model # HTS22GBMBRWW. Appx. 7 years old. Running but the freezer is blowing cool air and does not freeze.
Do you have frost build up on the back wall of the freezer ? If you have a even build up of frost on the back wall in the freezer section then you have a defrost problem.
If you don't have frost build up, and your fan is running as you described. then I would say you have a freon leak. This leak could be anywhere in the seal system, but most comonly will be in the evaperator.
the evaperator on this machine is a litter more dificult to replace and will cost more to have installed than others, The evaperator and the other parts required to install the evaperator will cost about $250 to $350 + Tax and Labor. If the evaperator is bad, I would buy a new machine.
Jan 12, 2010 | Refrigerators
Freon filled the kitchen. Freezer stopped freezing frigerator not cold anymore, can the refrigerator be repaired or is it gone?
Almost anything can be repaired...just depends how much you want to pay to get it fixed. The cost will depend on the location of the leak. If it just a bad braze you can problem get it repair for $250 to $450.00
If the evaporator coil/plate is bad it will most likely be cheaper to get a new unit unless parts are still under warranty.
Jan 09, 2010 | Refrigerators
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Sub-Zero 690 Side by Side Refrigerator Logo
279 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
