Question about Toshiba Satellite M35X-S114 Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
    Sergeant:
  • 161 Answers
Http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Posted on Sep 09, 2009
    Problem Solver:
  • 5 Answers
You can upgrade memory to One GB(1024 MB) or 2 GB(2*1024MB)
Memory type:PC2700 DDR333 SDRAM 2.5V SODIMM
    President:
  • 1,187 Answers
Always use as few memory chips as possible; one chip (1GB) is better than 2x512MB.
That way, you can expand easily without losing any me
mory.
By the way, if you add a single 1GB chip, you can also keep one of the ccurrent chips in the computer.
  • 76 Answers
It says in the link below you can get 2GB
http://reviews.cnet.com/laptops/toshiba-satellite-m35x-s163/1707-3121_7-31322069.html
    President:
  • 1,564 Answers
If you are running XP or Vista they will tell you the maximum amount of memory for your unit. It's under the system information page in the "help and support' opening page.
  • 10,515 Answers
Yes You can use 2 512MB of memory on this model.
That's absolutely fine. It would give you same benefit as 1 single GB of memory.
Thanks.
  • taran_2005
    taran_2005 Sep 09, 2009
    M35x series have 2 slots :-
    Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.
    Kindly check the data before confirming any information!!
    Thanks.
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
How to ram upgrade toshiba satellite
Before going for the upgrade make sure you read the specifications as to how much size your system supports,
Then take your laptop to the authorized vendor and ask them to upgrade it accordingly so that you do not have any compatibility issues later.
Jun 23, 2009 | Toshiba Satellite M35X-S149 Notebook
Not enough memory
  • your Toshiba Satellite M35X-S311 has the following memory configuration
  • Configured with 512MB
  • The maximum memory you can have is 2048MB (Max),
  • 2 memory slots using 1024MB PC2700 DDR333 SDRAM 2.5V SODIMM Memory modules (Both slots may be occupied). Go to a store and request for this memory specification and you will have 2GB of memory for all the programs you have listed here. Good Luck!
Mar 30, 2009 | Toshiba Satellite M35X-S311 Notebook
Is the cpu in a toshiba satelitte m35x-s163 laptop upgradeable ?
hi
You need to check if the model of your motherboard and the specs, that will tell you if you can.
Good Luck
Mar 27, 2009 | Toshiba Satellite M35X-S163 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
Maximum Ram upgrade?
this is the link
http://www.memorystock.com/memory/ToshibaSatellite2400103.html
In this link u have following details
1)Maximum capacity RAM Information Available
2)Toshiba Laptop Memory Installation Video
3)Laptop Memory SODIMM Installation Guide
If you r Satisfied with information provided from my side please give me good ratings thanks
If u require more information search in google
Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
Ram upgrade
http://www.bestbuy.com/site/olspage.jsp?skuId=7333218&type=product&id=1118845304999
Above is a site showing some of the type of memory that you need. The memory type is 333 Mhz PC 2700 SoDIMM memory. Installation would cost $39 at Geek Squad.
Apr 14, 2008 | Toshiba Satellite A60 Notebook
Open Questions:
Toshiba Satellite M35X-S114 Notebook Logo
176 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
