Question about Sony PlayStation® 3 (60 GB) Console
P3 not playing high def dvd
Have sharp 46" has high def.hooked p3 to play high def blue ray dvd no pic ture no sound when using high def cable pleas advise e mail craig_davenport_98 @verizon.net
  • 22 Answers
Make sure your tv input is on the right selection
Posted on Feb 22, 2008
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
I have for the first time hooked a sharp aquos LC-46D64U to my basic Direct TV cable (Not High -Def) and the picture lookd all ghosty and watery. I tried adjusting the picute controls and it seems to have...
A 46'' TV is zooming all the defects, to make sure is not a problem with your tv, try with a DVD Player using at least a set of Component cable or HDMI will be the best way to test it.
Dec 06, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a new HP Pavilion dv5t notebook (purchased 10/23/08). I can play regular DVD and Blue-ray DVD's on it with no problem using the HP QuickPlay software installed on the PC. I can also connect the...
This is a security feature of the High Definition Content that it does not allow veiwing of any high def content on dual displays.
There is a very simple fix to it...
Go to Nvidia control panel..
Select setup multiple displays..
Choose the option Single display ( one display at a time ).
Thats it.. This should enable you to play the blue ray dvds on the external display.
Regards,
Anup
Jan 01, 2009 | HP Pavilion dv7-1130us laptop
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
What does HDMI mean?
Only If you Play high def or blue ray disks on the player///regular disks will look even better then before but not quite as good as a high def or blue-ray disk!
I hope this fixes ya up!
(please use the rateings so we can keep this site FREE!)
Dec 14, 2008 | Hitachi 57F500 57" Rear Projection...
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Sony PlayStation® 3 (60 GB) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
