Question about Samsung CLP 300 Laser Printer
If I print 5 copies, the first one it is perfect and the in the other 4 it is missing 1 inch column on each side.
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Missing print
machine needs drum and developer, but a temporary fix would be...open front door near notice green handle where toner is replaced, look to the right of green handle and down about 2 or 3 inches, you should see a plastic or chrome cover the size of a postage stamp, remove the cover and you should see a 3/4 inch wide piece of glass barely sticking out, carefully grasp the glass and pull it out of machine, wipe the toner off the glass , put glass back in and replace cover , shut front cover and run copies .
Jan 30, 2014 | Ricoh Aficio 2015 Copier
93 mercury cougar turn signal flasher location
It's a 2 inch square by 1 inch thick black box with a 4 or 5 wire inline plug, located below the steering column just to the right side of the column.
Sep 03, 2011 | Mercury Cougar Cars & Trucks
I need to print mailing labels imported from excel to word in columnar order instead of in order by rows across the page.
hi Samajane,
I understand the you excel file has data that is stored column wise. Well you can first convert the column wise data to row wise data and then import it to you word.
To convert the column wise data to row wise data.
1.Select the data in your worksheet.
2.Right Click -> Copy
3.Create a blank worksheet.
4.Goto Edit - > Paste Special
5.Check the Transponse Option
6.Press OK.
Now you have converted your column wise data to row wise data and now u can import it to your word and print mailing labels
Dec 14, 2009 | Microsoft Windows XP Professional
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print Quality Problem
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
May 20, 2009 | Xerox Phaser 8560N Laser Printer
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Unusual paper size
Load the custom size paper in Paper Tray 5 (Bypass Tray). The Tray 5 screen will be displayed on the Touch Screen. Select [Non Standard Size] from the column on the left. Select the [Up] or [Down] arrow button to modify the X dimension of the custom paper size. The value range is from 147.32 to 457.2 mm (5.8 to 18.0 inches). Select the [Right] or [Left] arrow button to modify the Y dimension of the custom paper size. The value range is from 147.32 to 297.2 mm (5.8 to 11.7 inches). Select the appropriate paper type from the Paper Type column on the left. Select [Save]. Select [Tray5] from the paper supply section under the [Basic Copying] tab. Make any other required selections for the job from the Basic Copying tab on the Touch Screen. Place the original(s) in the Document Feeder or a single original on the Document Glass. Press the [Start] button on the Control Panel to copy hope this helps!!!
Jul 29, 2007 | Xerox DocuColor 12 Printer
Printing missing column
This could be several things-here is a list in order of probability... 1. transfer roller dirty, especially if inside of printer looks like it needs a cleaning. You could vacuum with toner vacuum or take it in for service. 2. scanner mirrors dirty. would need to be serviced by a technician. 3. scanner toner shield out of position-tech needed. 4. toner cartridge (even though its new) needs to be shaken horizontally-toner could be all on one side of hopper. Thanks and good luck...
May 15, 2007 | Lexmark E232 Laser Printer
Samsung CLP 300 Laser Printer Logo
26 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
