Question about Panasonic Kenmore Canister Vacuum Vacuum
Better bar doesn't rotate, kenmore whispertone 100
Better bar just stopped rotating. Can I fix this?
  • Chemist1961 May 11, 2010
    Look for a red reset button at the back or top of the Power Head. Try pushing it if you have one. If one the other hand you can hear the motor running inside the head and the brush isn't turning, or spins freely by hand, you need to replace the belt
    Problem Solver:
  • 12 Answers
Most likely your belt wore out and broke.
Here is a handy vacuum repair tutorial that should get you back cleaning.
Below is a short excerpt from the instructions. The link above will take you to the full version with images.
When your vacuum starts to lose cleaning power, requiring multiple passes to get an area clean, or the self-propulsion loses its zip, chances are you need to change the vacuum agitator belt. After only a few months of use, most vacuum belts stretch out enough to slip, causing the agitator to spin more slowly.
Replacing the belt is quick and inexpensive. New belts are available starting at about $5. Belts come in numerous brands and sizes, so bring the old one to the store for a guaranteed match.
Fifteen minutes, two screwdrivers and a new belt are all you’ll typically need to complete the job.
Posted on Sep 10, 2009
  • 144 Answers
Check to see if your belt is still on the beater bar, you many have to replace the belt.
Posted on Sep 09, 2009
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar not rotating
Remove the screws from the bottom of the power head.
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
I have a Kenmore Wispertone 300 cannister and I am trying to access the motor. There are four screws shown in the parts diagram. I need to remove the plastic on/off pedal to acess two screws. How do I...
I just encountered the same problem on a Whispertone 116 last evening. If it is the construction same as mine, there are four flexible plastic retainers molded into the top cover in the gap between the pedal and the motor cover. These are on the hinged side of the pedal. All four retainers must be bent in toward the interior of the vacuum simultaneously to release the pedal. A screwdriver does not work very well for this. What worked for me were four metal bars about 3/8" wide X 1/8" thick X 1-1/2" long. The pieces I used were actually the snap-off ends of some hanging file rails I found in my basement. Insert the four bars at the four retainers. They should fit snugly as they must push the retainers past the hinged portion of the pedal. To remove the pedal, rotate the pedal up in the same direction as the spring is pushing and it should come free from the motor compartment cover at which point you can access the other two screws. I suspect Sears has a special tool with four tabs to perform this trick in the repair center. Good luck!
Jan 03, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone 100 connection issues
find a used one at a vac repair shop, its just worn out
Aug 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Jan 14, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Panasonic Kenmore Canister Vacuum Vacuum Logo
231 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
