Question about Canon MP610 Photo All-In-One Printer
The PGBK cartridge won't print.
I have changed the cartridge and also replaced the printhead.
3 Suggested Answers
  • 193 Answers
SOURCE: Canon ip4300; new printhead and PGBK ink cart but it won't print
call ok canon 800 number..their better than India CAll centres.
Posted on Dec 03, 2009
  • 1584 Answers
Perform Print head clean should do the trick. May have to repeat.
My MP500 has stopped printing black
Two things, usually the printhead is bad and needs replacement, QY6-0059-000, on rare occasions I've seen the purge assembly not cleaning and purging the black properly, and that happens. I would change the printhead first.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Dec 03, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I am snow bird; printer turned off for 6 months. I shut down properly. Now when doing print nozzel check the top PGBK pattern whole center portion is missing. I have cleande, deep cleaned twice and wiped...
It's manually unclogging.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0062.
Nov 17, 2009 | Canon PIXMA MP960 Printer
Printhead is blocked but it's only the Black PGBK cartridge on my Canon MP610 printer. All other colours are working fine. I can't print a letter unless I select a photo paper.
try removing the black cartridge and with a q-tip and some rubbing alcohol clean the cartridge where the ink is. Re-insert and clean the heads.
Oct 30, 2009 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Not printing black ink after replacing cartridge
Unfortunately I have no idea which compatible cartridge you're using so it's difficult to provide a definite solution. However a few things to consider:
1. The cartridge needs to have a clear vent hole so if you haven't removed tape or a plug from a hole that was indicated in the instructions, you need to do this.
2. Try removing the cartridge and then touching the exit port on the cartridge with a Q-tip (cotton bud) to see if the ink flows to the cotton. If it doesn't you need to replace the cartridge.
3. Check the cartridge is sitting properly in the printhead.. The interface between the printhead, rubber grommet and the cartridge exit port is very important and the cartridge needs to sit in this properly.
My guess is that the compatible cartridge is not up to the job and you need to consider getting an OEM (Canon original) instead.
You may want to think about finding a refill kit and using the Durschtich (German) method of refilling using bulk ink and a chip resetter instead of compatibles.... Nifty-stuff forums have a LOT of information on this subject so it's well worth a look.
Hope that helps.
Martin
May 27, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My PGBK cartridge stopped printing. After doing the cleaning recommended through the properties help menu nothing changed. The test pattern doesn't show anything where the PGBK pattern should be - NOTHING!
After removing all the ink cartridges, I removed the print head and soaked it in propyl alcohol overnight. Then blew it out gently with an aerosol 'air duster' and washed it again in fresh propyl alcohol followed by another blowing out. After gently blotting the print heads on a soft tissue and replacing the print head plus cartridges, it necessitated two deep cleans to get the inks through and all now works again.
Make sure that you switch off the printer at its On/Off switch and not at the supply. I think I may have done this and left the heads not parked properly - hence the drying out!
Jan 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pgbk cartrige
Your printer works with the PGI-5BK cartridges, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Thx.
Feb 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
525 people viewed this question
old marine
old marine
