Question about Dell 924 All-in-One InkJet Printer
I lost power while printer was OFF. When power
I lost power while printer was OFF. When power came back on, printer power was ON, but printer is not communicating. I have tried both unplugging power and unplugging USB as suggested, but nothing works.
  • pistophchris May 11, 2010
    did you try another PC to make sure it isnt the PC that got the USB fried somehow? Otherwise the printer probably got damaged.
Power port missing
try to know the name of the printer then use the name to get the power port
Feb 19, 2014 | Dell (P513W) All-In-One InkJet Printer
Lost electric for lexmark z611 printer in moving. What kind of electric source do I need
Lexmark InkJet Z611 Printer AC Adapters and Power Supply Unit. Contact sparepartswarehouse.com
Feb 15, 2014 | Lexmark Z611 InkJet Photo Printer
I have a e350d that when I turn on, just displays a single row of grey boxes and will do nothing. HELP!!!!!!!!!
The printer may have been the target of an electrical event such as a voltage spike or surge, and has been lost. You can try to unplug it from the power, unplug it from the computer, and wait 2 minutes. I usually push the power button on a printer with issues while it is unplugged to make sure it has lost all stored power. Plug it back into the wall and see if it responds to the power button. If the same thing happens, or if there is no response at all, then you may need to replace the printer. Or contact the company that supports it, If it is under warranty, or a service contract.
Jul 20, 2013 | Lexmark E350d Laser Printer
"fail to warm up" see troubleshooting
Try this remove the cartridge and return it back. Turn it off for 1 minute and turn it on. If still problem, Remove the power cord to 30 second and return it back with power supply turn off. and restart the printer
Jan 05, 2011 | Brother MFC 7420 All-In-One Laser Printer
Just had black cartridge filled. got error message I thing 1203. tookout cartriges and replaced them again. lost all power. unplugged from wall and adapter in back of printer for a minute. plugged back in...
First remove the cartridge and try to switch on the printer.
The error code 1203 is shown if its faulty shortened cartridge.
Printer identify such sort of cartridges as overfilled one.
Nov 30, 2010 | Dell 962 Photo All-In-One InkJet Printer
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Power outage now printer won't work
1. Have you tried turning your printer power button off.... unplugging your printer open all the door cover and close them back.. plug your printer into another wall outlet....then turn it back on.... if it turns back on...(GREAT) 2. If it does not(TURN BACK ON).durning a power outage it can damage the main board in your printer...and if so you will need to have it serviced.....
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
No Power
only in your power lead if not take the lead out the back of the printer then wait 30 sec then reinsert should work
May 12, 2008 | HP PhotoSmart 7760 InkJet Printer
Lost cable
The connections are fairly generic and most electronic stores have them.  Even the hardware store will have them.  Take a photo of the inlet port on the printer with a digital camera or you camera phone if you have one. Even trace it with paper and pencil.  Run down to the store and buy one. Any length will do and you'll be back in operation in no time.
Oct 12, 2007 | Office Equipment & Supplies
Dell 924 All-in-One InkJet Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
