Question about HP Computers & Internet
Pioneer DVDRW DR-KW08HB ATA Device driver issues
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
I have this issue with my Pioneer DVDRW DR-KW08HB ATA Device on an HP Pavilion dv9000 laptop.
  • 76 Answers
To me that sounds like something got corrupted with Windows, if you have a restore CD, or know how to reinstall your OS I would recommend that, AFTER you back up your files though as you will lose anything you had saved on there. But that could fix it, or it could be the drive is bad also.
Posted on Sep 09, 2009
I have a Pioneer DVDRW DR-KD08HB and getting a code 19 can u help me fix it i had a similar issue on another computer and this website online with mit techs helped me in seconds and i lost their website ...
Code 19 error comes when windows cannot start this hardware device because its configuration information in the registry is incomplete or damaged. You need to download the drivers once again and install them. Please check the links bellow :
http://www.gearsoftware.com/support/drivers.cfm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 10, 2010 | Computers & Internet
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Pioneer DVDRW DR-KD08HB not working on HP Pavilion Solved the problem once from fixya and now the problem returned. Anyone??
You should really give more detail on the issue for people to solve the problem quicker. If you can't see the dirve on your drive list but it show up under device manager and getting error 39 you can try the following link.
http://msbin.com/kb/entry/53/
Sep 08, 2009 | Computers & Internet
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer dvd driver has stopped working
to go to system registry click on start>all programs>accessories>run then type regedit and press enter. Don't change anything unless you know what you are doing. It sounds as though it could be a driver problem though, try updating the driver from device manager. Right click the device and click on properties then update driver.
The only other solution would be to restore your computer to an earlier time when you know that the drive was working properly. Click on start>all programs>accessories>system tools>system restore and choose a date when you know everything was working okay. I hope this helps.
Oct 22, 2008 | Computers & Internet
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
415 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
