Question about KitchenAid KGSI901PBS Gas Kitchen Range
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
I have a similar Kitchenaid range, less than five years old. The "stop" button for the timer no longer works and a few of the number buttons no longer operate either. I tried to remove the cover over the control panel but could not get anywhere after removing the burner control knobs. I've also read of numerous problems with the control panel after using the self cleaning feature. Now I'm hesitant to use the self cleaning.
  • 725 Answers
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Posted on Sep 09, 2009
The start button will not start the oven, all other options on the control panel are working, just the start button.
not good
have you clean it or split something at some time
the igniters can be inspected
wait till gas clears
user manual page 10 ...start button has a control lock design
does the user manual help
https://www.manualowl.com/m/KitchenAid/KGRA806PSS/Manual/249033?page=12
May 18, 2016 | KitchenAid KGRA806PSS Gas Kitchen Range
I done baking and try to shut off the oven. The off button doesn't response.
Hello & Welcome to FixYa
As the off button wont respond so the problem is with the membrane switch that is bad and needs replacement. This switch usually comes with the control pnael and to replace it you'll have to buy the control panel. Please get back to me if you have any other questions.
Kevin
Jan 10, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
New kitchenaid electric range hums when it is on. doesn't stop until we turn it off. Why?
could be a relay humming or the power supply is noisy. Other users with this model have reported same issue. Seems common but has no interference with quality
Sep 28, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Jul 14, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRC608
Hi does this range have a fuse for the circuit/timer board its not on at all but burners still lite and starter works if the is a fuse will you tell me where its at or is the top board fryed or the bottom board yes there is a bottom board on the right sie base in draw area dont know what to change i thought maybe it was only a fuse but can't locate it thanks for your help with this . model kgrc608lss0
Jul 30, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRA806PSS
try pressing stop/clear press and hold timer for 5 seconds after making sure there is piower to the range
Jan 22, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGSI901PBS Gas Kitchen Range Logo
1,009 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
