Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do i replace ink in my officejet 4215 all-in-one
emissionwiz
  • 77201 Answers
SOURCE: i can not install my hp officejet 4215
have u gone on the HP web site and checked for updated software? I have 2 HP printers and both had issues, downloaded the newest software at HP site support and cured the problem.
Posted on Jan 16, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: I have a hp officejet 4215. It has a scanner, but
For some reason the scan button on allot of HP printers doesn't seem to work.You can go thru "printers and faxes" on your "start" menu.After opening Printers look in the left column for "scanners and cameras",click it.Then your printer will come up,highlight it.Left column again,click "get pictures" and it will walk you thru the scanning process.
Posted on Jan 11, 2010
zooless
  • 109 Answers
SOURCE: how do i install the ink cartridge of a hp
OPEN THIS LINK AND GO TO PAGE NO 82
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
YOU WILL FIND THE INSTRUCTIONS
YOU CAN ALSO FIND A LOT OF GOOD INFORMATION ABOUT YOUR PRODUCT IN THIS PDF DOCUMENT
MAKE SURE THAT THE PC HAS ADOBE READER IN IT
GOOD LUCK !!!
Posted on Mar 27, 2010
Testimonial: "I finally figured it out yesterday, after my fingers were colored in ink. I saved this information. So kind of you to go to the trouble!"
  • 3741 Answers
SOURCE: i need directions on how to lift out ink cartridge
turn the printer ON.then lift the cover on the right side of the printer to the top. the cartridge carriage will automatically move from left to right for few seconds then the carriage will stop to the right corner where you lifted the cover.then to remove the cartridge out its a very very simple method.place the thumb of your hand on the cartridge top and one finger on the base of the cartridge and slowly pull it towards down position.the cartridge will get unlocked as you push it bit lower side the down side.then once the cartridge is got down it will get loose so easily pull the cartridge towards yourself.it will come out.in the same way do it for other cartridge also.there are many -- many users facing this same problem.removing and reinserting cartridge looks bit hard but its very very simple.while fitting the cartridge if you are getting it hard to fit then.check on the cartridge there is brown dotted circuit.in the printer also there brown dotted circuit.this both circuit should match each other while fitting.so you get in what position to hold the cartridge.the sticker on the cartridge should be on top position.it hardly takes 2 second to remove and reinsert the cartridges ,once the cartridge carriage gets stopped in the position from where you can remove the cartridges.let the cartridge carriage get stopped in the right position then only remove the cartridge,other wise the cartridges will get blocked. this will help.please do rate the solution.keep updated for any further assistance if more help required.thanks.
Posted on Apr 29, 2010
Testimonial: "TYVM!!! Your information really helped me.Now i feel very comfortable in attempting to work on my computer.I'm very NEW to this and was scared to try."
vinay229229
  • 1121 Answers
SOURCE: hp officejet 4215 all in one, upgrated from
Brows the link.This Windows 7 patch fixes some printer functionality after upgrading Vista to Windows 7. Link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=351106#N221
Posted on Sep 29, 2011
How do i check my ink levels on hp officejet 4215 printer
ideally diagnostics should return the info about ink levels.
but in case they dont you can try below
1. Hp Solution Center > Settings > print settings > printer toolbox > Estimated Ink level
2. go to control panel->printers->go to priinter properties it should show ink levels
Apr 11, 2012 | HP Officejet 4215 All-in-One Color Photo...
How do I install my ink cartridge for a hp officejet 4215 all in one
Turn on the HP printer. Lift the printer cartridge door, which is the right side of the printer, revealing the black and color ink cartridges. Push down on the front of the cartridge you need to replace and pull it out slowly. Unwrap the new ink cartridge and peel off the tape. Insert it at an angle into the cartridge slot. Apply gentle pressure until it clicks into place. Close the cartridge door and press "OK" when prompted.
References:
HP User Manuals: HP Officejet 4215
Hope this helps you :)
Mar 07, 2012 | HP OfficeJet 4215 All-In-One InkJet...
How do I check the ink levels on my ho 4215
Start the HP Printer Assistant software, and click "utilities".
Click "display ink levels".
Sep 22, 2010 | HP Officejet 4215 All-in-One Color Photo...
Will 27 work on 4215
HP 27 cartridge is not compatable for this printer. Supported cartridges are :
Back : HP 56
Color : HP 57 , HP 28
Photo cart : HP 58
May 08, 2010 | HP Officejet 4215 All-in-One Color Photo...
My hp officejet 4215 needs a driver for vista
The best source for HP drivers is www.partsurfer.hp.com the drivers are listed under support and drivers.
Oct 13, 2009 | HP Officejet 4215 All-in-One Color Photo...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
No, only when it indicates that it is out of ink, does it stop printing. It is warning you now, so that you can purchase more, and be ready when it does run out. If it will not print now, then there must be some other problem.
Dec 06, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
