kenmore progressive upright (direct drive) with bag has low suction and the beater bar does not rotate.
Also, it is not obvious how to get inside the vacuum
First of all you look for a reset button on the motor and press it in with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vacuum. Remember that the brush will not turn in the upright position. if this will not works then most probably the beater bar belt is broken. Take the cover off the beater bar to check it.
I am having a problem with my Kenmore Progressive upright with the Inteli-Clean vacuum. I need to...
(More)
I am having a problem with my Kenmore Progressive upright with the Inteli-Clean vacuum. I need to replace the pedal and I have the replacement part I ordered from the site, but I cannot remove the original broken pedal. I attempted to find directions online and was unsuccessful. Is there a maintenance manual or instructions I can access so I can get my vacuum up and running again?
When I turn the vacuum on, the noise sounds like a circular saw, it is unbearably loud. I suspect it...
(More)
When I turn the vacuum on, the noise sounds like a circular saw, it is unbearably loud. I suspect it is a problem with the suction or connections but am not sure how to fix it. My container is empty so it is not because it is over filled with particles.
When I turn the 'intell clean system' on the lights go off as if carpet is clean & I know...
(More)
When I turn the 'intell clean system' on the lights go off as if carpet is clean & I know it's dirty! Suction immediately decrease.
