Question about Brother MFC 7420 All-In-One Laser Printer
I have purchased an new HP computer that operates on Vista - My MFC-7420 will not print - I get nothing at all - it just stays in the sleep mode. HELP!!
    President:
  • 1,996 Answers
Just to make sure you have the correct links. Go here to download the updated software installation package for your printer: Copy the instructions on that page and save them to a notepad file or somewhere on your computer, where you can refer to them.
Then download the uninstaller from here. You must run this on your computer and reboot before installing the updated drivers. Here are instructions for the uninstall tool. AFter uninstalling the software, make sure the usb cable is unplugged, and cycle the power off and then on to the printer.
Then install the printer software by logging in as admin, extracting the zip file (double click on it), open the setup directory and double click on setup.exe.
This will run the updated installer to install the printer on your system.
When you are prompted to by the software, connect the usb cable.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 09, 2009
  • efs_perpends
    efs_perpends Sep 10, 2009
    Were you able to get it installed and working ok?
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Can't get brother out of sleep after 99 minutes inorder to pring
Try plugging the mfc into another usb port on the computer. The ones in the back are closer to the processor, usually work better.
Mar 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printer doesnt come out of sleep mode (Brother MFC7420)
I'd be happy to give you the solution to this problem :)
You'll want to go into the menu and choose these options: 1,6, and 2. The final stop should give you the sleep menu.
The printer is setup for a default of 5 minutes. But you can change it from 00 to 99 minutes. To just shut it off, press the Options and Start button simultaneously and that will do the trick.
Here is the link to the manual: http://www.brother.ca/en/products/pdf/manuals/MFC7820N-UG.pdf
If I wasn't specific enough, the solution is on page 2-6
-Ernest
Apr 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 all in one Scanner not working
sorry but is the 7420 compatible with Vista? what does the box say?
Nov 08, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
93 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
