i turn tv on the green light comes on and a few seconds later tv is off and red light is blinking i unplug then plug, green light comes up then stsrt blinking red, tv doesn't start.
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board. There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
I am starting to see green "pixelating" on the bottom center of the picture. Is there a...
(More)
I am starting to see green "pixelating" on the bottom center of the picture. Is there a fix for this?
TV works fine but makes a "popping" noise periodically, particularly after it's been on...
(More)
TV works fine but makes a "popping" noise periodically, particularly after it's been on for a while. I just want to know whether this is indicative of a problem, or just something these TV's do.
I have a phillips 50'' plazma tv about a yr old, in the bottom lefthand coner there is a little blue...
(More)
I have a phillips 50'' plazma tv about a yr old, in the bottom lefthand coner there is a little blue light when the tv is on, now, when I go to turn the tv on, it doesn't go on and that light blinks 6 times with a different color, what's up?
My tv won't keep my adjustments and returns to the 'soft' picture setting after I power it off. How...
(More)
My tv won't keep my adjustments and returns to the 'soft' picture setting after I power it off. How can I get it to use my personal settings when I turn it back on?
