Question about Dryers
Makes thumping sound on start up,thumps or knocks ocassionally while drying
I had called the repairman for this problem and was told that this is normal. The heavy drum makes a flat spot on the roller while it is stopped. The flat spot makes the sound when it starts but stops making the sound after the flat spot goes away after rolling around a bit. Have not had a problem with the rollers for the last 7 years. It makes the sound for the first 30 sec or so, then goes away. If you have this sound all the time, you may have a defect on the roller.
Posted on Jan 27, 2010
  • 725 Answers
This is probably your drum rollers going out. While you are replacing the rollers, I recommend you also replace the belt and also blow all the lint out of your dryer while you are inside the unit. This will prolong the life of your dryer as well as prevent a potential fire from lint getting caught on fire. Call us for your parts and we will be sure to get the right ones for you. We need the brand and model number off your dryer. Ella :>)
Posted on Sep 09, 2009
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Dryer drum is starting to make a thump, thump sound when rotating. Everything else works fine. Belt is good.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 26, 2011 | Dryers
The dryer makes a thumping sound and doesn't dry clothes.
heatman101
Jun 24, 2011 | Frigidaire Electric Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Engine knock 2001 hyundi elantra
Is it a thump thump thump and is it effected by engine speed?
Mar 20, 2009 | 2001 Hyundai Elantra
Thumping sound
Most likely the rear drum support has worn and dropped down.
Remove the drum and replace the rear ball and cup drum support.
Mar 20, 2009 | Frigidaire FEQ1442ES Electric Dryer
Oil and trans leaksalso a thumping sound over 35mph
first have the tyres removed and checked on a balance machine
the noise could be fro belt movement or bad tyres
Apr 30, 2017 | 1993 Pontiac Trans Sport
Dryers Logo
106 people viewed this question
Top Dryers Experts
