Question about Bosch SHU9925UC Built-in Dishwasher
Not filling water is not going in dishwasher
  • 725 Answers
This sounds like your water inlet valve is out. We have parts, so please call or email us and we will make sure and get the right part out to you. BTW: I love the Bosch appliances the most! Hope this helps you! Ella
Posted on Sep 09, 2009
    Genius:
  • 1,036 Answers
Your system may have something called "aqua stop".
This will shut off the water supply if there is even a slight leak into the base tray.
I would suggest you disconnect the unit and check for any water in the base tray.
If there is, use an old towel to soak it up, then try and find the cause of the leak.
Often, it is the large seal at the junction of the pump and filter assembly where it connects to the metal body of the washer.
The only real way to find it is to remove an access pannel, connect it up and watch for any leaks - keeping your hands well out of there!
Disconnect power completely before touching anything for obvious safety reasons.
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Why is my dishwasher not filling with water?
Fill the tub up using large pots of water if it runs but doesn't fill back up for the rinse cycle then you need a new water valve
May 10, 2014 | Maytag Dishwashers
My hotpoint dishwasher wont go past filling up, but its doesnt fill!!
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 19, 2010 | Hotpoint 23 in. BFV62 Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
No water going inside, but water to dishwasher fine
If it is supposed to be the filling cycle and you have no voltage to the water fill soleniod then a timer contact is not making connection or there is no voltage to the timer relay. Fix it!
May 07, 2009 | Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
No water going into dishwasher?
either the isolation tap is in the off position or the fill solonoid is faulty on the water inlet pipe within the appliance. hope this helps!
Dec 20, 2008 | Maytag 24 in. MDB5600A Jetclean II...
No water entering
Check to see that the water is turned on to dishwasher. If so then your fill valve is likely not working. To confirm check to see if you are getting 120v ac to the fill valve with a multimeter with the dishwasher trying to fill. If voltage is present then the fill valve is bad.
May 24, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Bosch SHU9925UC Built-in Dishwasher Logo
454 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
