Hi I have an old toshiba 2060 that displays this casette is out of order. dont know where to start to diagnose the problem. can you help me out. thanks
Well first Which Cassette is it the First one or second one and if so can you discribe what you mean by "Out of Order" what it won't lift Paper ? indicate their's paper install please clearify firstWell first Which Cassette is it the First one or second one and if so can you discribe what you mean by "Out of Order" what it won't lift Paper ? indicate their's paper install please clearify first
You can't post conmments that contain an email address.
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / damaged....one of the gears may be also damaged.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Open front cover of your 2060. Inside the copier, on the left side, there is a blue lever labeled "A". Press lever "A" towards the left while pushing down on the top of copier....this will unlatch the **** shell and allow the upper portion to lift upward. The waste (used) toner container is located in the center of front frame (semi-clear plastic). Lift upward on container until it clears the frame, CAREFULLY pour the contents into a plastic lined trash can. Replacement is reverse of removal.
Have you tried the manual feed tray? Which way is the letter size paper being feed in? LTR or LTR-R. You may have a reg. clutch that is slipping. I would also look to see if you have any paper jamed behind the paper tray and make sure the paper trat is displaying that ltter paper is in the papre tray the same way as displayed. Good Luck
Changing the developer is a procedure for service technicians to do. You might want to ask that question on copytechnet.com. There are Toshiba service technicians on that can help you with that.
First of all what Error code is being displayed????? Need a place to start from...... It could be one or two or all threethings----- Fixxing thermal fuse, Thirmister, fuser heating lamp...
