Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
I have tried to install the speedstream 2624 to a cable modem from time warner and no luck.
  • 3,153 Answers
You should first make sure that the modem and router are individually
set up correctly.
Read the guide for router and modem first and if any of it may apply to you then try and do it.
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc by wire and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Write down any numbers where it says DNS too as they may be useful (you only need the ones with numbers not the ones with letters)
Now do the same thing with your modem
If that too has the same IP as your router in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an internet explorer page (it will fail but that's ok)
In the address bar type the number you got for default gateway above for the router e.g. 192.168.1.1 and press ENTER
When it asks for the user name, give it the one you gave it when you set the router up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there. This will allow your computer quicker access to finding things on the internet
Now look for the save settings button and do so.
Reconnect the modem and router. The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
If it was a conflict that should have set you on the right path
Posted on Sep 09, 2009
  • 76 Answers
I am assuming you had a different device hooked up to the modem directly before, sometimes you may need to call up time warner and let them know as some of the modems do not like to renew IP's properly.
My siemens speedstream 2623 router needs software disks that come
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 10, 2010 | Siemens SpeedStream 2624 Router...
Router was given to me i have no installation instructions,thought i had it connected right, but was unable to pull up any internet pages,
theres a reset button on there somewhere. with the power on, hold reset till you see the router reset then unplug your modem, wait 2 minutes, plug it back in. then plug the modem into the router. then plug the router in.
Oct 17, 2009 | Siemens SpeedStream 2624 Router...
How do I connect the SS2624 to HughesNet
Are you trying to set up the router for the first time.
Make sure that the computer is able to go online when connected directly to the modem.
Click Here for more info about router set up. YOU can follow the direction for the DSL connection
Oct 08, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Cant access internet siemens speedstream n6520
I solved this problem, by hitting the reset button on the bottom of the modem, now I have no problems
Jul 28, 2009 | Siemens SpeedStream 2624 Router...
How do i connect my speedstream 5100 to dsl aftr i turn it on?
Call your service provider.
i.e. Time Warner, Cox cable, Verizon, etc.
Talk to Tech Support. They'll run a line test and guide you through any problems.
Let me know if you have any other questions.
Best of luck!
Feb 28, 2009 | Efficient Networks SpeedStream 5100 Modem
Problem with modem
If the Online LED on your modem is red, it means that it is not synchronized with the connection that you have from your Internet provider.
Try to reset the modem by holding its reset button for 30 seconds then power it off. After 10 seconds, power it on and observe the Online LED.
If you also have a username and password from your Internet provider, you may set those on the modem configuration.
Sep 08, 2008 | Siemens SpeedStream 2624 Router...
Speedstream router 2623 doesn't work
it could be possible that the router is just not in sync with the modem. you can try to power cycle the devices first by turning them off. then turn on your modem first, wait for all the necessary lights to turn on, then the router and then the computers. check if you'll be able to connect to the internet again. if not, you may need to access the router's page to check if it's properly configured or not.
hope this'll help you and just ask me if you'll have other concern
ciao!
Jul 10, 2008 | Siemens SpeedStream 2624 Router...
Wireless connection was working/now it isn't
in that loptop see you got n/b which wireless
if they are same like what class are ?
Jan 02, 2008 | Siemens SpeedStream 2624 Router...
Lights are gone
Well, If You've Had It For Four Years, It Definitely Sounds Like Your Router Has Died So To Speak. Most Routers Only Tend To Last A Few Years Of Being On Constantly. I Would Suggest Buying Another Router Because The Cost Of Repairing This One Really Isn't Worth it. Good Luck, Brodey
Sep 15, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Siemens Speedstream 2624
Find the reset button on the rear panel of the wireless device and follow the factory reset instructions below: 1. Power Off the router. 2. Hold the Reset Button down while you Power On the router. 3. Continue holding the Reset Button until the Status (Red) LED blinks TWICE. 4. Release the Reset Button. The factory default configuration has now been restored, and the Router is ready for use. The DSL/Cable Router's default IP Address is 192.168.254.254 To establish a connection from your PC to the DSL/Cable Router: 1. After installing the DSL/Cable Router in your LAN, start your PC. If your PC is already running, restart it. 2. Start your Web browser. 3. In the Address box, enter "HTTP://" and the IP Address of the DSL/Cable Router, as in this example, which uses the DSL/Cable Router's default IP Address: HTTP://192.168.254.254 The first time you connect to the DSL/Cable Router, the Setup Wizard will run automatically. (The Setup Wizard will also run if the Router's default settings are restored.) This should get you in the right direction. ZT3000 "Beta tester of "0"s and "1's"
Aug 20, 2007 | Siemens SpeedStream 2624 Router...
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
246 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
