Question about Hunter Ceiling Fan Control Switch
The pull chain came out. how do i fix it? - Hunter Ceiling Fan Control Switch
  • bulldogchief
    bulldogchief May 11, 2010
    What type of fan? Ceiling, box, oscillating? Normally if the chain pulls out you need to go get a new switch but I need more info on the type of fan and model number.
  • 34 Answers
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch, there should be three screws holding the light fixture to the fan, then one plug will connect the light to the fan. then unscrew the brass cap where the chain broke then cut the wires close to the switch, then there are only 2 wires to wirenut together and there is no incorrect combination to reconnect them.
Posted on Sep 09, 2009
Pull chain on Hunter ceiling fan pulled completely ot of fan by cleaning crew. Can it be repaired? And if so is it worth the cost? Thanks
You can get another chain with a hook at the end if there is any of the chain at all left on the fan to fix it.
May 15, 2017 | Hunter Dryers
HOW DO I FIX A LIGHTING CHAIN THAT BROKE INSIDE THE HOUSING OF THE FAN?
You have to buy a new pull chain, usually two wire. Take light off fan and put new pull chain on as you take the old one off.
Sep 12, 2014 | Dryers
Harbor breeze fan remote
If the fan has a pull chain then push the Hi button and then pull the chain until it's on high. Then don't pull the chain! If that's not your problem then check the capacitor in the fan.
Jul 15, 2013 | Dryers
I can't seem to figure out how to properly assemble the chain onto my new Husqvarna 316e
I have a picture to show which way the chain will go on to the bar. Look at the cutting edge and that will face the bar tip across the top. There are teeth on the bottom of the chain that fit into the race (or guide slots) on the bar. The chain will run around the clutch at the engine end and the clutch will have gears that engage the teeth to pull the chain around. When you have the chain on the bar, pull up on the and keeping tension on the bar tip. should be a screw on the engine side of the bar to adjust the in/out of the bar to tighten the chain. Keeping the up tension on the tip, adjust the chain until you can pull the chain up only the width on a dime in the middle of the bar on the bottom. Pull the chain around the bar a few times, please wear good gloves. Hope this helps Fix Ya up. mcneb_38.jpg
Jun 28, 2011 | Husqvarna Garden
My saw just stopped on my chain got stuck and came off as i was pulling it back out of the cut, well i thought it was just the chain came off and it would be a simply fix. but its still not working right?...
First, make sure the chain break is released. (top handle pulled all the way back)
Second, remove the chain cover. You will see a tab on the chain break (a band around the Centrifugal clutch) that fits into the handle/cover. Make sure that is in place and reassemble the unit.
Did this fix your problem?
Jan 06, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need to fix the pull chain on a model P3086
It uses a standard pull switch available at most hardware stores, just make sure you get one with the same No. of speeds and transfer one wire at a time.
Jun 30, 2010 | Dryers
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
Oct 01, 2009 | Hunter 22451 The Brookline Brushed Nickel...
Pulled chain to slow down fan speed. Chain came out of the housing. Yikes. What should I do? Perfetually have the fan running or can I take it apart and fix it?
Turn the fan off at the breaker. Is there any chain still hanging out? If yes, buy new section of chain at hardware store. If no, buy new pull chain switch at hardware and replace.
Jul 27, 2009 | Dryers
Pull chain
this is the type of switch that attaches to one wire only do you understand?if connects to live wire to break the conection.
thank you for useing fixya
Please turn off main befor fix
RATE ME
Apr 20, 2009 | Solar 2-wire Pull Chain Light Switch For...
Dryers Logo
877 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
