Question about Mitsubishi WS-65809 65" Rear Projection Television
My tv wont turn on
The green light comes on and goes out when you try to turn it on. I held the menu imput buttons down and received a code of 2 2.
  • 556 Answers
22 indicates the vertical output IC could be shorted.
Posted on Sep 10, 2009
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
Tv wont turn on green light comes on then goes right out could there be a blown bulb
Do the self check this model has: WHEN GREEN LIGHT COMES ON AND THEN GOES OUT:
On front of set press and hold both the menu and input (device) buttons at the same time and hold both for at least 5 seconds and release both.
Watch the power light, it will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find with a comment here and I will tell you what it means.
SD TECH
Feb 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Why wont my mitsubishi big screen tv turn on? the green light comes on but then shuts right back off.
Model number given indicates it should be a 2000 year model.
If so, it should have the self check feature; try to turn the set on and when the green light goes off: On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks,pause and 2 blinks (2,2 error code is most common one). It will repeat the error code several times.
Let me know what error code you find and I will tell you what it may mean.
if this told you something you did not know rate this solution as "very helpful" as I do this here for free.
You can post a comment on this page.
Regards, SD TECH
Aug 11, 2010 | Mitsubishi VS-60607 TV
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Mitsubishi WS-55859 power light comes on and then goes off.
I get an error code of 2- 2 x 10 etc Ten times I saw two blinks of the on light. I had a power relay replaced in the year one ,fixed it.then. what do I do now to fix it. What part would you replace thanks.
Dec 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
No startup
For my FTR9965, it is necessary to physically unplug the
power cord from the box before you are able to enter the service codes. The sequence is:
1. Unplug the box for a few seconds.
2. Plug it in again.
3. Turn on the box with the front panel power switch. Wait for the green light to come on.
4. From the remote, quickly enter 062596 plus the info key.
5. A message comes on the monitor warning you that you could really screw things up if you don't know what you're doing, and do you really want to continue? If yes, hit any button on the remote. You only have a few seconds to respond.
6. The "stand alone" option is near the end of the "service" menu list. When you find it, change the "no" to "yes".
7. Go back to the main SAM menu, scroll down to "Store", and hit OK. I'm assuming this makes the "yes" selection permanent.
8. Enter "00" to exit SAM.
Aug 08, 2007 | Philips E-Box FTR9965 DTV Receiver
Mitsubishi WS-65809 65" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
