Clarification please:
1. Is your computer on a network?
If so, a network drive letter may be in conflict with the flash drive's letter. Try temporarily" disconnecting network drives, or boot computer locally, instead of to the network.
2. If not on a network, open "My Computer" to see if any drive netters are assigned to a "Removable Disk" ... maybe Drive E:
If so, that's it!
Please comment to clarify or if you need more help.
If the USB drive isn't showing up in my computer, you have one of three problems. One, the driver is messed up. Try the drive on a different computer, if it works there the driver is messed up on your computer, we can fix that. Two the circuit board in the USB drive is corrupted/damaged and you need to have the drive transfered to a new enclosure, normally simple but as this is a 1" Hard drive you may need a specialty shop to do the work. Three, the drive itself is damaged, you will definitely need help from a pro trying to recover the data assuming it's worth the expense.
Try the drive on a different computer and report back with the results, if it works there I'll step you through repairing the driver issue, if it doesn't work there let me know and if you need the data off the drive and require a pro reply back with your Country, State and City, I'll pass along a recommendation or two.
Hope this helps FixYa,
Chris
Was this helpful?
Yes
No
Popular Solutions for Memorex Mega TravelDrive? 4 GB
For some reason, my vista computer will no longer support my memorex flash drive. I tried it in my...
(More)
For some reason, my vista computer will no longer support my memorex flash drive. I tried it in my friend's computer--she has XP--and it works but, when I tried it in the Vista computers all in my household, it won't even open. The light blinks and that's it...I can't get to my files and I really need them right now... Can someone please help me? I really need to get to those files >..<
I last used my memorex mega traveldrive 4 gb in April and put it aside. When I plugged it in the...
(More)
I last used my memorex mega traveldrive 4 gb in April and put it aside. When I plugged it in the laptop last night, the light lit briefly and stopped. Windows gave me a warning that says it was not recognized. Can't get it to read on another computer either. Thought it was a drivers issues. The only drivers on the memorex website was for win 98. Downloaded and installed it anyways, but is still not working. What to do? I have very important files contained only on this drive!
Hello, For some reason when I attempt to access my portable vault, reguardless of the computer I am...
(More)
Hello, For some reason when I attempt to access my portable vault, reguardless of the computer I am on, it is telling me that it has encountered a problem and needs to close. Not sure what happened. Is there a solution to this so I can access my very impt. files w/in my vault? Thank You, Jeremiah Soto
my memorex USB travel drive (4GB) is write protected and has no lock/unlock option. What can I do to...
(More)
my memorex USB travel drive (4GB) is write protected and has no lock/unlock option. What can I do to use this drive? Thx
