Question about EuroTech EWF150 Front Load Washer
Does not agitate
My EuroTech front load washer does not agitate. We recently had the pump replaced and now it fills, the timer goes through the cycle, and it dumps (no spinning). Does this machine have a belt? Can it be fixed without a REALLY expen$ive service call? Where would I get the parts?
  • halfunit Dec 11, 2007
    What is a motor coupler?
  • 537 Answers
Motor coupler could be bad.
Posted on Dec 10, 2007
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't wash
Hi!
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
EuroTech EWF150 Front Load Washer Logo
132 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
