Question about Garden
How do I take the top off of a Quantum 5.5 Power Pro mower in order to rewind the pull chord?
  • 11,896 Answers
There is 3 screws that will need to be taken off, then cover should lift off.
Posted on Sep 09, 2009
How do we rewind the skag 48"commercial mower pull chord
spring is broken in pull cord houseing need to take of take in to shop they will fix for 20.00
Sep 16, 2014 | Garden
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
When I pull chord to my troybuilt mower no tension on chord
if you pull the top cover off you will find there is a tin cover in the center that moves the small plate that engauges into the cup shaped part on top of the engine i have seen the screw just back off
Jun 02, 2012 | Garden
It won't start. The pull chord won't pull out. Even a little. It was out at one time, in the loop on the mower handle, but I had to let it go into the motor and now it won't come out.
You will probably have to disassemble the rewind assembly and either replace the rope and/or straighten out the cord and properly reconnect it to the flywheel connection. Kits usually are available at the Sears parts store or lawn and garden centers that handle lawn mowers everywhere.
Best wishes,
TF
Jun 03, 2011 | Garden
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
When i pull the chord its realy hard and wont
Sounds to me that the engine brake is the problem. Pull the top cover and be sure the pull starter is free and if it is then look at the engine brake just below the cover to see if it is releacing.
Apr 16, 2010 | Mtd 22" White Outdoor Self Propelled High...
When i try to start it just clicks
SOUNDS LIKE PROBLEM IS IN THE TOP COVER AND NOT ENGAGING FLYWHEEL WHEN PULLING CHORD. I THINK ITS A PLASTIC HOUSING THE ROPE IS IN. PROBABLY STRIPPED OUT TEETH. PULL TOP COVER OFF AND LOOK UNDERNEATH FOR DAMAGE. TAKE TO LOCAL SMALL ENGINE MOWER SHOP,NOT HOME DEPOT THIS IS A SPECIFIC PART. THEY CAN ORDER YOU ONE,NOT TOO EXPENSIVE. THEY SHOULD SHOW YOU HOW TO WIND SPRING UP AND REINSTALL ROPE. ALSO LOOK AT SPRING ACTIVATED CATCHES THAT LOCK TO TETH TO ENGAGE ROTATION,MAKE SURE THOSE ARE GOOD TO
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
I waz starting the awn mower and had resistince from the pull cored so i pulled and now the pull cored is dangolling and want trigger a start
Soundas like the rewind spring is broken. Remove the top housing and see if you can reset the spring by removing the cord, hook up the broken end, rewind the spring with a screw driver...lock it in the tension position and then reinstall the cord.
Jun 15, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
