Question about Maytag Neptune MAH5500B Front Load Washer
I need to install a motor control conversion kit on a maytag clothes washer washer model number is MAH4000 AWQ first 2 digits of serial number are 40 need to intall motor and new control board
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Posted on Feb 11, 2008
SOURCE: Maytag Neptune washer model #MAH4000AWW,
we have the exact same probem. did you find the solution to this problem?
Posted on Jul 14, 2009
  • 155 Answers
SOURCE: mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Posted on Nov 05, 2009
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Wont complete the cycle reads Lr how do i unlock the door
maytag had many problems with this issue. "Lr" is a locked rotor in the motor. there is actually a motor control conversion kit maytag put out to fix this issue. And depending on the series number (first to numbers in the serial #) of your washer, there is a 10 year warranty for this kit. the kit is a new dc motor, motor control board, and harness. you should call maytag to see if you machine qualifies for this, the kits are expensive if you have to buy it. if you door wont unlock, and you need to get cloths out, open the lid for the detergent. look on the right side and the front inside where you put detergent in. you will see a green or red cord, that is the door lock release. if you pull on it, it will unlock the door, just dont pull to hard. good luck, shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
I would like to know the age of my machine, whether I should have it repair or buy a new machine. The model #MAH4000 Maytag Neptune. Lydia Dunbar
The age is determined by the SERIAL NUMBER. Please post back with your complete serial number, particularly the last two letter designations. With that info I can tell you month and year the washer was manufactured.
Jul 14, 2008 | Maytag Washing Machines
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
