Question about Proscan 32LB30QD 32 in. LCD TV
I need the remote control code for Proscan tv with dvd player
I have a Proscan LCD tv with dvd player and I want to program my Direc TV remote to control it. the tv is a lcd thin screen and 26" screen. THANKS
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Posted on Jan 18, 2010
    President:
  • 1,077 Answers
This web site link will help you program your remote.
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020
Just keep in mind that the possiblity that not all the remote code programed inside the remote will work. I haven't had a Directv remote work on a flat panel tv as of yet. They don't seem to be making the remotes work with flat panel, but give it a try.
Posted on Sep 09, 2009
Looking for the AT&T uverse remote control Proscan 24" LCD combo TV/DVD
If you wish to know its programming procedure, check the sites linked here. it is difficult to type all all here by this wondow. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
My remote quit working.
If ur direct tv remote have problems,or it defective.Talk to ur direct tv satalite provider to get another remote.U can try website like 1-800-Remotes factory original.To buy ur Proscan tv original remote.
May 03, 2010 | Proscan 32LB30QD 32 in. LCD TV
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
TV, DVD
The codes for an RCA TV are: 002,021,011,102,114,211,302,312,318,320,406,409,411,420,502,
511,514,519,601,702,711,719,720,809,810,811,901,911,912 & 914
For the Magnavox DVD Player are: 441 & 442
Good Luck!!
Jason
Feb 03, 2008 | Philips PM-8FS LCD Touchscreen Remote...
Programming Code
Barring the right codes to make this thing work, I have resorted to running the numbers (ie 000 thru 999) to "stumble" across the right combination...accordianman
Dec 29, 2007 | TruTech TT320
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan 32LB30QD 32 in. LCD TV Logo
1,312 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
