Question about Samsung U900 Soul Cellular Phone
How to delete a number from memory - Samsung U900 Soul Cellular Phone
How do you delete a number from memory
The 29875 is an answering machine. It doesn't have a phonebook.
Sep 14, 2014 | GE 29875GE Digital Answering Machine
My Nokia E63 display a message of ' Phone memory full " and also says 'Please delete files'. Which files to delete and how ? Thanks. Partha
I woud clean up your mobile phone by:
  • Copying your photos on your handset to your PC/Laptop and deleting most of the photos as they can take up a large amount of memory.
  • There are physical available memory limits to the total number of SMS/Messages in your Inbox/Outbox/Sent/Other folders: delete old SMS/messages.
  • There are physical available memory limits in the total number of contacts: delete all redundant directories entries.
You can also try using a bigger microSD card to alleviate your memory limitation.
Hope it helps.
Dec 14, 2010 | Nokia E63 Cell Phone
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Problem and credit card payment already submitted on canon pixma Please advise. Problem with fax memory, can't print faxes
1 Press [FAX], then press [Menu].
2 Use [< ] or [> ] to select <MEMORY REFERENCE>.
3 Press [OK].
4 Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
▼ If you select <PRINT DOCUMENT>:
1. Press [OK]. 2. Use [<] or [> ] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
3. Press [OK]. 4. Press [< ] to print the first page only, or press [> ] to print all pages of the document. 5. To print another document, return to branch-step 2, or to finish printing, go to step 6. ▼ If you select <DELETE DOCUMENT>:
1. Press [OK]. 2. Use [< ] or [> ] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>. – <ALL PRINTED DOCS.>: Deletes all the printed documents stored in memory.
– <1 DOCUMENT>: Deletes a single document stored in memory.
3. Go to step 5. 5 Press [OK].
▼ If you selected <ALL PRINTED DOCS.> above:
1. Press [< ]. Press [> ] to cancel deleting, and the machine returns to the standby mode.
If you selected <1 DOCUMENT> above:
1. Use [< ] or [> ] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
2. Press [OK]. 3. Press [< ]. Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1.
4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6. 6 Press [Stop/Reset].
Sep 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Deleted number by mistake how can i retrieve this
If the number has been deleted from the phone's memory...then you're lucky...however...if the number has been deleted from the SIM card's memory...no way to get it back...
Jul 27, 2008 | Cell Phones
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
How to clear the memory
Press FUNCTION key then 9 key. The display will ask you to ENTER FILE NO. OR ^. You want to enter ### as the file number and press SET to delete all files. (You cannot delete the file while it is being sent). The display will then show DELETE ALL FILES? 1:YES 2:NO. Press 1 to delete all files.
Jul 25, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung U900 Soul Cellular Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
