Question about HP OfficeJet 7410 All-In-One InkJet Printer
7410 all in one loading display constantly running.no response when I press the power button or any function key. Appears to just be stuck in mode.will not respond at all.
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
0xc18a0001 Error. I've tried several recommended procedures from your site....no luck. Any help would be appreciated
Solution 1
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Solution 3 (Conversation with a HP TECH)
Earnest: May I have the model number of All-In-One you are using?
james cowan: c6250
Earnest: Thank you for information.
Earnest: James, please let me know the room temperature in which printer is replaced
james cowan: 67 degrees f
Earnest: Okay
Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
james cowan: ok
Earnest: Press and hold the "left arrow" key.
Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
Earnest: Please ignore the above steps, James
james cowan: ok yes nothing seemed to do anything
Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
james cowan: COxxFN0723BR
Earnest: Okay
Earnest: 2. Press and release the right arrow button until the display says "System Configuration Menu
james cowan: ok
Earnest: 3. Press and release the "OK" button.
james cowan: ok and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
james cowan: ok
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Earnest: Let me know once you are done with the above steps
james cowan: ok its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
james cowan: ok
Earnest: Let me know the message displaying on the front panel of the printer
james cowan: printer preparation occuring - do not interrupt
Earnest: Okay
james cowan: ok its done
Earnest: Let us print a self test page from the printer now
james cowan: ok deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
james cowan: ok printing
Earnest: Okay, please check whether all the colors pritned perfectly on the test page
james cowan: perfect
Earnest: Great..Cheers!!!
james cowan: thank you very much
Earnest: James, now you can continue using the printer
Earnest: I appreciate your efforts and patience in trying to resolve the issue.
Solution 4
  • Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
  • Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal". Display should say "Support" and display the FW rev: COxxFN0723BR (or something like that)
  • Press and release the right arrow button until the display says "System Configuration Menu"
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "CANCEL"(Annuler) button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 60 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
  • print a test page:
Courtesy of LEH.
Jul 02, 2011 | Computers & Internet
WON'T PRINT IN WINDOW IT SAYS INK SYSTEM HAS FAILED ERROR:OXC18A0001
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
  • If the error is still there continue reading...
1. Get the unit into the "Support Menu" by following the steps below
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
C. - Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | HP DeskJet 5150 InkJet Printer
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My 2006 C280 was due for service B , and I just did the oil change only. How can I reset service B message on the car computer ?
Reset process should be listed in the owners manual.
Should be something like turn car to on(not running) press trip button twice, turn to off and hold trip button till it resets.
Apr 19, 2010 | 2007 Mercedes-Benz ML320 CDI
HP 7410 will not boot. It powers up and the HP logo appears on the screen with a progress bar. The display then scrambles and the power light flashes green. No buttons work or do anything.
connect the printer directly to the wall socket for the power supply if it is connected thrugh surge protector.
perform a reset :
unplug the power cable .
press and hold # and 6 key on the printer..
plug in the cable wait for 20 secs then release the buttons..
after this the printer will re-initialize .. this may take few mins..
and chek after that
Oct 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
HP OfficeJet 7410 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
