Question about Everex StepNote VA4103M Notebook
Screen won't appear.computer turnson ok but its screen stays black
  • 512 Answers
Make sure you haven't turned it off, hold the function key down and cycle the CRT/LCD key. Otherwise you are back at solution 1 and 2.
Posted on Sep 09, 2009
    President:
  • 1,185 Answers
Place the computer screen sideways on to a reasonable light
Can you see the icons , if you can, the backlights have gone which is generally the inverter which will cost around $120 to fix.
If there are no images to see it is either the graphics card or the LCD
One way to check that is to plug another flat screen monitor into the port on the laptop
If that lights up it is the LCD if it does not then it is the graphics card
  • 28 Answers
Typically, this is caused by the flourescent backlight failing, or the ballast that runs the backlight failing. In these situations, the entire LCD panel is usually replaced, as the ballast is typically matched up to the exact model of LCD panel.
Dell st2410b monitor won't stay lit
Ok, same issue here as well. Monitor would come on for 1/2 second and then the backlighting will go off. It's next to impossible to tell, but if you shine a bright flashlight at the screen, you can make out the video signal/desktop.
I have now replaced all the Capacitors except the very large one (didn't come with the kit that was available.) None of my caps looked bad (bulging) including the large one. Unfortunately, I still habe the same issue
So my question is....large capacitor replacement or something else?
Nov 29, 2012 | Dell ST2410 Monitor
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Canon powershot sx10 cannot download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Jun 21, 2012 | Canon PowerShot SX10 IS Digital Camera
Won't boot screen black
A black screen on startup can be so many things! I have learned this lesson the hard way. Never turn off the computer when it is half way through the boot procedure. Even when it is taking forever, or having a major problem you must let it run through if possible. Interrupting it once may be ok, but twice or three times is a no no. After you have carelessly restarted and shutdown a few times the black screen may appear. But this time it may be beyond repair for the average computer user. http://tips4pc.com/articles/computer%20troubleshooting/how_to_repair_a_damaged_boot_sec.htm
Good Luck!!!!!!
Dec 30, 2011 | Acer Extensa Computers & Internet
I have a problem with World War 3 Black Gold. I've just installed it on my PC. I'm using Windows 7 Ultimate 64bit and the game won't start. I double click on the WW3.exe, small black screen...
I had the same issue and resolved it by downloading the World war 3 black gold 1.2 Patch - install this and you should be fine. I will still ask you to select a resolution but it will actually let you now.
I got mine from here
http://www.shacknews.com/file/454/world-war-iii-black-gold-12-patch
Sep 19, 2011 | JoWood Productions World War 3: Black Gold
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
My zune screen wont appear
Try pressing BACK+LEFT+CENTER as it is coming on. Then reinstall the firmware.
hope this helps
chris
Dec 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Everex StepNote VA4103M Notebook Logo
117 people viewed this question
Top Everex Computers & Internet Experts
k24674
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
