I have a Carrier Debonair 220 thermostat and the display is completely blank, so nothing can be set. Is there a way to reset, or a reason why there is nothing displayed?
  • 128 Answers
Please check there is power comes to the thermostat first.
Posted on Sep 09, 2009
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
Aug 07, 2017 | Carrier Heating & Cooling
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
Dec 14, 2015 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Carrier HVAC thermostat not fully displaying digital read out. Control bottoms doesn't work have to depress really hard and eventually works
Does it have a battery backup in the unit? If so replace them. If its an older model used frequently oil from your hands gets behind the buttons which causes intermittent connections and can cause display error. Remove the unit, carefully open it up and clean all contact surfaces with q-tip and a bit of rubbing alcohol. May solve your problem. While your at it make sure all wire connections are tight. Mark all wire locations during disassembly to make sure they go back in the right place.
Jan 01, 2015 | Carrier Heating & Cooling
Carrier debonair 400 won't heat
Hello my name is Willie of GMP mechanical services out of Centreville Virginia. I need some more Information about your AC unit is electric or gas heat. Is there a fault or fail signal in the digital display anywhere?
Jan 18, 2013 | Heating & Cooling
Blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
1,733 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
