Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE side by side freezer shelves falling down
I have a GE side by side and the inside freezer walls seem to have moved outwards, causing the shelves to fall off of the supports.
    New Friend:
In the hope that this helps someone else:
We have an older (about 1997) Sears side by side fridge (with water and crushed/cubed ice in the door) that still works well. But the fridge side door had warped over time (widened) and the shelves (maybe they shrunk - who knows?) tended to fall out. No fun cleaning up after a couple of jars bang against each other and break spilling who knows what over everything.
The door has a row of pins (14 per side) molded in place that support the shelves. The pins measure .395" in diameter and protrude about 7/16". The shelves hook over the pins and rest against the back of the door.
I suppose I could have hunted up a replacement part but given the age not worth bothering with and probably would have cost big bucks even if I were able to locate something. Not to mention the bother of storing everything in the fridge and taking it apart.
So to fix the problem I bought a three foot length of clear 3/8" x 9/16" plastic tubing (the stuff you would use in conjunction with a small pump) and cut 1/2" lengths which fit perfectly over the pins thus making them 1/16" longer per side. The tubing is actually 10mm I.D. (.393") x 13 mm (.512") O.D. not the nominal 3/8 (.375") advertised. The tubing was only a couple of bucks plus tax at the local "Ace hardware". Actually less than two foot was plenty but if needed I have some left over if it cracks, molds or the door grows/shelves shrink a bit more over time.
Don't you just love it when a plan comes together!
Thanks for listening to my gloat
John
Posted on Mar 02, 2013
  • Ann Taylor
    Ann Taylor Apr 24, 2014
    The tubing is too thick and the shelves will not go over it :( It was a nice idea though ... too bad it does really work
  • Ann Taylor
  • 25 Answers
This appears to be a known problem with at least a couple of GE models (It has been happening in our freezer too). There is a GE Service bulletin at https://customernet.geappliances.com/OTIS/fs/home_images/REF01-10.pdf that seems to describe the fix as them sending out new shelves (and maybe someone to install them?)
Posted on Jul 12, 2010
  • lorevale88 Apr 28, 2011
    I think GE makes terrible products.
How do i move shelves up or down in freezer
You lift up the front of the self and pull outward and up.
Jul 11, 2017 | Whirlpool Refrigerators
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the difference.next what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
Shelves not wide enough to stay on shelve supports
your ansewer for not the rade qus,,,,,,,,,,,,,,,,,,,,,,, ok
May 22, 2009 | GE EasyCam Webcam
Freezer shelves fall
They are made for ease of installation but unfortunately, not stability. Slightly bend the sides outward, making the shelves slightly larger.
Feb 09, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I did the tubing solution others mentionedand it worked great.. instead of the 1/2" OD 1/4" ID reinforced tubing. I bought Polyethylene tubing at 3/8" OD, 1/4" ID.
Cut the tubing into lengths that will fit between the rails, split with a utility knife down the whole length. Use a screw driver to force open the end and slip the tubing over the rail.
Pic attached shows the tubing cut along side and forced on to the rail along with a pic of the tag that was on the tubing in an inset. I bought a 25' roll because i was in a hurry and not paying attention. I did 2 shelves, needed something under 1' per side per shelf. so I used 4' total for the whole project.
Jan 20, 2009 | Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
947 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
