Printer needed low on ink, took serveral days to get one, then I get a error code 0xc05d2381 and unit wants me to shut it down, and can not get printer back on line. Jim
Kodak esp 5250 printer error has occurred
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Nov 21, 2011 | Office Equipment & Supplies
ERROR 6000 my pixma 350 is a little over a year old it was pretty low on ink but still working and then suddenly when i went to print something the paper went in about a 1/4 of the way and stopped and the...
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back. finally check the paper indetect optocoupler, clean the sensor and the rollers and reset once again.
Thank you for using Fixya
Sep 23, 2011 | Canon Office Equipment & Supplies
What is the solution for error code e247 ir2000
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
Sep 05, 2011 | Office Equipment & Supplies
What is Error Code 6000
Sep 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hp all in one printer office jet 4215 carrtrage error put new ink in and shut it down
Aug 02, 2011 | HP Officejet 4215v All-in-One Printer
Getting a error code 6000 on mx700 all in one please help
Jul 25, 2011 | Canon Office Equipment & Supplies
My printer show error e28, help solve it, please
Jul 12, 2011 | Canon Office Equipment & Supplies
Have hp 450c orange cartridge light keeps blinking checked all cartridges only black cant get ready light to come on 3x so light keeps blinking.took out black cleaned it but still wont blink ready
Jul 09, 2011 | HP DesignJet 450c InkJet Printer
Error code 5100 ??
Jul 07, 2011 | Office Equipment & Supplies
78 people viewed this question
jasbo
jasbo
