Question about Canon imageCLASS D780 All-In-One Laser Printer
How to replaced fuser on the Canon ImageClass 780
I need instructions or the service manual for replacing the fuser assembly.
Thanks
    Genius:
  • 1,689 Answers
The steps are posted on the reference guide found in the link below from Canon
http://gdlp01.c-wss.com/gds/0300000515/imageCLASS_D780_D760_D761_Reference_Guide_EN.pdf
Posted on Sep 09, 2009
If problem persist contact dealer or service rep turn the main power on e301-0001
This is a fuser error, the fuser replacement for this machine is best done by a technician as there is moderate disassembly involved..
Your local canon warranty agent will be a good place to start.
This same printer engine is used in a few HP printers and multifunctions and the fuser is available from HP as well. Though HP are usually slightly dearer.
If you want to have a go yourself the part number is one of the following, depending on your electrical grid voltage un your part of the world
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 120 Volt
RM1-7576-000
or
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 230 Volt
RM1-7577-000
Oct 26, 2013 | Canon ImageCLASS MF4450
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
Please help me fix e000 for canon laser multifunction mf5750. Thanks
E000 is a fuser error code, you'll need a professional help to replace the fuser! Sorry, no easy fix for this one.
Dec 14, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
E300 error message
Hi Good day!! It may be the fuser problem. u may need to replace the fuser or buy a new unit.
Nov 19, 2010 | Canon imageCLASS D340 All-In-One Laser...
Que fait un E000002 code d'erreur signifie-0102 canon ir3100c
Check the fuser assembly (the "hot" part where the paper exits the machine). Replace as needed.
Bon Chance!
Oct 31, 2009 | Canon imageCLASS D320 Digital Copier
Canon D880 fuser
With an offset #2 phillips screwdriver and some patience you can do this- we have been fixing PLENTY of fusers on the imageclass series-you can get the fuser out thru the exit side of the copier.
1. UNPLUG COPIER , pull platen to left with grey lever
2.remove one screw for upper plastic cover cover pulls down and out
3.remove 2 screws on lower exit cover this comes up and out
4.remove small plastic cover on left side of exit assembly as you face end of copier.
5.pull back black plastic sheet to expose 3 connectors one plugs into circuit board two plug into heater or fuser assembly. unplug these
6.with your offset driver remove 3 screws holding fuser to frame of copier -these will be pointing up.
7. lift fuser up and carefully work out of copier.
check for stuck papers or damaged fuser film sleeve.
To reseat fuser and replace panels go slow and easy the panels fit back in kinda funky it takes a bit of tinkering.
We do not turn the copier upside down to remove the fuser and have replaced about 20 of the fusers or installed a new fuser sleeve.
Good luck and ask all ya want if more assistance is required.
Apr 05, 2008 | Canon ImageClass D880 Copier
Paper wrapped around fuser roller
http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d780/products.html
im not 100% familiar with this printer but iv replaced ALOT of parts on ALOT of different types of laser printers(color and mono) the fuser invariably will come out either the left or the right side, last place would be the middle. either way they are always fairly easy to get to being they are the second most common part replaced in a laser printer. Tipicly located right by the toner in the paper path. this should be easy to find.. IF you still need help finding it send some pictures with either side taken off or the "hood" up. and ill point it out to you. BE CAREFUL OF the contra wire. it will zap you.. even if the printer is unpluged.
Jan 22, 2008 | Canon imageCLASS D780 All-In-One Laser...
System error
Go to this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=10561 In the "please enter your question" (gray bar area) type in E000. It will give you three options for resetting the machine. If these don't solve it, you'll need to replace the fuser (fixing) assembly.
Jul 29, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageCLASS D780 All-In-One Laser Printer Logo
215 people viewed this question
old marine
old marine
