Code f23 for whirlpool washing machine
Error code f23 for whirlpool washing machine, what does this mean.
  • 1 more comment
  • thrca
    thrca May 11, 2010
    What is the model number of this machine? It should be located inside the door on a sticker.
  • Linda Luckhurst May 13, 2013
    AWOE 8759B
  • MARIA DEBRINCAT
    MARIA DEBRINCAT Jun 16, 2014
    mfw108edwt
    Problem Solver:
  • 6 Answers
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Whirlpool F23 code error
f23-whirlpool-washing-machine-error-code.jpg F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Aug 31, 2014 | Washing Machines
Whirlpool AWOD6727 washing machine displaying error code "F23". Help please?!?!
Could be a slow drain time issue. Excess wear makes it drain slow.
Mar 17, 2017 | Whirlpool Washing Machines
F23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Jul 04, 2012 | Whirlpool Washing Machines
F 23
The meaning of the code depends on the machine's manufacturer.
On Siemens built machines (Siemens, Electrolux, hotpoints etc.) F23 Means that there is overflow and anti flood device has been activated.
In this case:
Disconnect power.
Remove all water at the base of the machine.
Take off the rear panel, or access the drain pump from front door(depends on model).
Check drain hose height and check hose connected to drain pump.
Connect power back.
If problem does not clear after connecting back, replace pressure switch.
With Wirlpool built machines instead (Whirlpool, Maytag, Kenmore etc.) f23 means there is a communication within the CCU and the MCU.
CCU is the main control module (central control unit), and MCU is the Motor Control Unit. MCU is a sealed module located deep inside the appliance, and connected on one side to the motor, and on the other to the CCU. Testing F23 on a Whirlpool is more difficult and requires a technician. In this case all you can do is disconnecting power, if error does not go away call the service number listed on manual.
Regards.
Ginko
May 19, 2011 | Washing Machines
The error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Jul 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
7,194 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
