Question about Canon PowerShot S500 IXUS 500 Digital Camera
Only Red When I turn the camera on the screen shows only a blur and not of the image of what I am taking, but just a color blur or a white blur, depending on the lighting. when I take the picture I get what shows on the screen. When I turn off the display and take a picutre the picture comes out like what is on the screen. Please help
  • Canon Master
  • 4,738 Answers
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable camerasOnly Red - 1.gif include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 14, 2007
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Hallo, my canon powershot A420 camera shows horizontal white lines in LCD screen mostly in night shots and the day light shots appear blurred as if more light is entering and the image is not clear.
I am afraid this seems to be a hardware error in the sensor. If the image is purplish in color when blurred it is similar to my and another user's problem. He/she contacted the manufacturer and they said they can fix it for $250. I am not a repair specialist so there may be a simpler cause and solution- good luck.
Dec 03, 2010 | Canon PowerShot A420 Digital Camera
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
No image -- just colors on led and photo
I found the same fault, but for me it is intermittent. I have tried all sorts of things to clear it, but the best seems to be leave it turned off for a while. I bought my Ixus 400 in Sept 03 and the fault started in Jun 07. It shows already taken pictures with no problem on review on the LED screen, but the screen blurs (with motion) and records that same blurred image.
Sep 28, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Sony DSC-W70 LCD Problem
You will need to describe what you see on the LCD in more detail in order for me to tell you what the problem is. There are two different issues that can cause things like what you are seeing. 1: Cracked LCD. You will see lines which resemble cracked glass. You will see bright vivid colors with specks of black or stark white all over. The image problems may be only in one portion of the screen. The LCD is made of glass, so if you look closely and see patterns that look like broken glass - this is your issue. Replace the LCD. 2: Bad LCD connection. You will see distorted colors, the screen may blank out and flicker when you shake the camera or press on the housing near the screen. If neither of these describe what you are seeing, post back and give more details and I will respond further. David Millier Advance Camera Repair
Feb 21, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC W70 Problem
Feb 21, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
