Question about Maytag MGR5750 Gas Kitchen Range
HELLO, WE HAVE AN OLD, SMALL, MAYTAG GAS RANGE. IT HASN'T BEEN USED IN YEARS, THE OWNER LIVES IN GERMANY. THE BURNERS ALL LIGHT JUST FINE, AND THE PILOT LIGHT IN THE BROILER SECTION LIGHTS JUST FINE.THE PROBLEM IS THE OVEN WILL NOT COME ON AT ALL. WE CAN'T READ A MODEL NUMBER AND WE LIVE REMOTE IT TAKES 7 HOURS TO GET TO A HARDWARE STORE. PLEASE HELP.
    President:
  • 1,714 Answers
The 'thermocouple' is probably bad ...or dirty. It's the thing sticking into the pilot flame. You could try sanding it off with emery cloth (metalic sand paper) or regular sandpaper. If that doesn't do it, replace the thermocouple.
Posted on Sep 09, 2009
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I have a Maytag Performa gas stove. The burners on top work fine. The oven part glows when I turn it on, but it does not heat up. Is there a pilot light that I can light, or is this a completely...
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Sep 25, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven works just fine, but my burners won't light unless I use a lighter. I think it might be the ignitor may have went. Is there any advise you can offer
When you turn the burners on do you here them sparking ? if not the spark module has gone out it's the most common failure when burners dont light
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Maytag MGR5752BDW / MGR5752BDQ /...
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
My old garland gas range, model J38H0, has 3 problems. one of the large burners only burns low, even when fully turned up, the oven won't light at all, and the other large burner ignites at the air intake...
Most likely the igniter is no good and does'nt get hot enough 2 start the oven. Check and make sure their is no blockage to the burners sometimes they get loaded with food and or dust
Sep 03, 2017 | Garland H283 Gas Kitchen Range
I recently bought a used Maytag gas range model #crg9700aaw. I am having an issue as the lower gas burner in the oven will not ignite. The broiler turns on and works fine, all the burners work fine as...
I had same problem, same model. Twice in 4 years. Was the lower ignitor gone bad. First time I assume to old age. 2nd time wife overloaded a roaster pan and it overflowed during cooking, and got liquid/**** on the ignitor somehow and killed it.
New one is $43 (http://www.repairclinic.com/Shop-For-Parts?s=t-crg9700-%3d%3d) online. More like $65-75 locally.
Tip: Upper (broiler) and lower ignitors are identical. For a quick test: Swap out the top one to bottom position and see if it works.
It has just today happened AGAIN to me 7 months later. Hence my being online for this.
It's an old horse, and 2 burners up top are acting funny for some time now. Rather than throw more good money into it I think I may trash it and just buy a new stove.
Nov 24, 2010 | Maytag Kitchen Ranges
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Jul 15, 2009 | Maytag MGC5430BDS Gas Cooktop
Maytag MGR5750 Gas Kitchen Range Logo
89 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
