Question about Creda 18 in. BC20 Built-in Dishwasher
Draining water from dishwasher
How do i drain the water stuck at the bottom of dishwasher without switching it on. high water level keeps triping the fuse. creda model.
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Creda 1000 Superspeed, stacked: Motor does not run
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Posted on Dec 03, 2008
barkencoa
  • 3463 Answers
SOURCE: I have a creda simplicity 1000 and it will not
Chrck pump, and or filter if it has one for blockage or malfunction.
Please rate my solution.
Thanks.
Posted on Jun 27, 2009
  • 6277 Answers
SOURCE: Creda IW160D wont drain I've taken
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the main motor. Motors will show weaknesses when commanded to turn and particularly to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 26, 2011
powergentry
  • 8 Answers
SOURCE: my Creda simplicity 1000 washing machine wasn't draining or spinning now there's no power light coming on and does nothing when i turn it on is it un repairable
It could be a lot of different things. Maybe the timer. If you know someone who has a volt meter and knows how to use it. Find you machine with a Google search, look for trouble shoot washing machine timer. That's the way I would do it. You want to look for a open in the electrical system *{the switch} like a broken wire inside the switch. Make sure to unplug the machine first. You won't need the power on for the first tests. A volt meter can be purchased for under $10. and any home repair store or box store.
Posted on Dec 14, 2014
E3 water drainng error
Some drain problems come from the washer drain hose not being high enough to allow for the water to fill in the dishwasher. Make sure the hose is held as high as the washer top as possible before it drains into the sink drain pipe. A good example is your cloths wash machine the drain hose comes from the bottom of the machine then it goes up to the drain that is higher than the basket. This keeps the water level high enough to wash clothes. The dishwasher works the same way. The drain hose must be slightly higher or as high as the needed level in the machine to work. In most cases as high as the dishwasher top or close to it. Simple raise the drain hose.
Jan 20, 2014 | Samsung DMB28AFS Dishwasher
Dishwasher won't drain
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
Apr 07, 2012 | AEG 23 in. Favorit 44070Vi Built-in...
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
The drain/inlet button keeps flashing. I have cleared out the bottom of the dishwasher but the red drain/inlet has continued.
two things i would check. First see if you can take the hose off where the water goes into the drain pump, this will be below the wash tank. more than likely there is something stuck in the. I would also check that the air bell / air pipe is not blocked. this controlls the water level. if it fills o.k it is not a water level issue.
kevin
sime catering equipment
Jan 06, 2011 | Miele Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Viking dishwasher that does not stop draining cycle - keeps on running
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
May 17, 2009 | Viking DFUD042 Built-in Dishwasher
I have a Matsui MS160SLI dishwasher it keeps on draining and will not fill with water. I have tried everything in the manual but nothing works. Help.
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Apr 13, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Thanks for the help
there is a float switch in the base which when operated, turns everything off and turns the drain pump on
Aug 21, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Creda 18 in. BC20 Built-in Dishwasher Logo
23 people viewed this question
Top Creda Dishwashers Experts
Owen Barnes
Are you a Creda Dishwasher Expert? Answer questions, earn points and help others
